JPEG datatype
    MarK
    Posts: 641 from 2004/1/25
    hi all,
    is there a way to speedup MorphOS datatypes rapidly? i mean, i have lots of 8-10 mpix jpeg files, and displaying such large jpeg files (2-4 megs each) is awfully slow (1 per 3 secs or so), i'd love to get some high speed jpeg rendering, is this possible? imo peg2/g4 is fast enough to decompress such jpeg file in fraction of second...
    thanks for any advices.
    bye, MarK.
  • »06.04.08 - 10:45
    zukow
    Posts: 658 from 2005/2/9
    datatypes use libjpeg so speed should be the same in all loaders using this lib (like my reggae class, ibrowse or kiero's showgirls)
    [ Edited by zukow on 2008/4/6 14:17 ]
  • »06.04.08 - 11:16
  • mk
    mk
    Posts: 72 from 2004/5/24
    akLJPG datatype /prefs:
    Dithermode: -> None
    DCT Decoding: -> Fast Integer
    Fancy Upsampling: -> off
    Color Quantizing: -> Fast
    Image Scaling: -> 1, 2 or 3
  • »06.04.08 - 11:23
    CISC
    Posts: 619 from 2005/8/27
    With such large images there are more bottlenecks than just decoding it, if it's scaled to match screen there's an obvious slowdown, and if it's not the transfer to gfxmem will slow it down as well...
    Anyway, without MorphOS 2.0 you should see speedups in several areas for things such as this with a G4, f.ex. scaling in both Ambient and ShowGirls are AltiVec-optimized, and even jpeg-decoding in itself is. There are also various other ways the system in general will benefit from a G4.
    However if you were looking for something to speed things up right now I suppose the other tips you got is as good as any.
    - CISC
  • »06.04.08 - 13:17
    jcmarcos
    Posts: 1178 from 2003/3/13
    Very true. You are talking about a huge amount of information here. Even decodified, moving it along is quite a task.
    Mmm... Sexy... Pity that finding Altivec hardware is so hard now. Perhaps finding a MacMini is easier than a G4 Pegasos. Genesi, roll on that Efika 8610!
  • »08.04.08 - 05:13
