PegXMac 2.0
    zhulien
    Posts: 119 from 2004/8/21
    hi, just wondering if anyone has successfully installed pegxmac 2+osx on their hdd? I got as far as installing pegxmac on the hdd, then running the osx installer only to have it crash sometime during the install (after choosing the osx hdd partition). I am within the first 8gb of the hdd and it's OSX 10.2 (cdrom version)
  • »14.02.07 - 12:04
    jalla
    Posts: 57 from 2004/10/4
    I have same problem using MOLK 0.7 and OSX 10.4 (dvd version). Crashes at different points every time I try.
    MOLK is installed on the MOS partition.
    Pegasos II/G4/512MB/Radeon9200
  • »15.02.07 - 07:28
    HydroUK
    Posts: 7 from 2006/8/30
    Hi, Its alot easier to just use an entire hdd i found. I have it running nicely using a secondary harddisk just for the macos system (PegXMac 2 booting from the pimary hdd). Also if this is your first time usin g u may wanna increase the sound buffer in molrc.sound to get the sound smooth.
  • »15.02.07 - 11:03
    magnetic
    Posts: 2129 from 2003/3/1
    Hydro
    I did not know that about the sound buffer. This has been an issue with MOL for some time now. When trying to use MAC sound apps I get sound probs. What do you suggest I set it to please?
    magnetic
  • »15.02.07 - 15:50
    Posts: 1932 from 2003/10/19
    Yeah it would be great if i could get cleaner sound out of my MOLK install as well. Please let us know!
  • »16.02.07 - 02:45
    zhulien
    I guess if some of you claim to use it, it must work then right :D
    which versions of MacOS are you using? perhaps mine crashes due to version of MacOS rather than PegXMac?
  • »20.02.07 - 10:12
    CountRaven
    Posts: 566 from 2007/12/10
    just found an older verison. Is there any link that will drive me to the 2.0 one? Thanks in advance.
  • »10.03.08 - 23:57
  • mk
    mk
    Posts: 72 from 2004/5/24
    > zhulien
    I have installed PegXMac2 and MacOS10.4 (Tiger) one Peg2(G4) successfull, but used not more.
    A known problem.
    Create partition before start installer.
    [ Edited by mk on 2008/3/12 7:13 ]
  • »12.03.08 - 03:42
  • mk
    mk
    > CountRaven
    PegXMac2 was only available as torrent, but this torrent exist not more.
    But i have pegxmaccds.zip (include big (668MB) pegxmac2.0.iso for Peg2 and little Peg1 and OS4 Distri) storaged.
    Give me a Website with >= 858MB free Space, send me a passwort (privat message) and i will upload this Archive.
    [ Edited by mk on 2008/3/12 7:14 ]
  • »12.03.08 - 04:05
    Cego
    Posts: 738 from 2006/5/27
    PegXMac2.0:
    http://www.pegasosforum.de/dload.php?action=category&cat_id=74
    [ Edited by Cego on 2008/3/12 18:51 ]
  • »12.03.08 - 16:31
    magnetic
    You guys should really use MOLk. IMHO Its much better than Pegxmac (but I havent tried latest version)
    I run Molk with osx 10.4 latest and its excellent. Usb works, even usb 2.0 from a pci card. Also, cd burning works and networking and sound (though could be better)
    Anyone with recommendations how to improve sound for me please advise. I also have a SB live card around I can use as well to offload cpu time..
    magnetic
  • »13.03.08 - 03:29
    SilkWorm
    Posts: 54 from 2005/4/12
    magnetic
    Did I understand you correct? Are you using SBlive card for sound output in MacOS under molk?
  • »14.03.08 - 04:24
    Tronman
    Posts: 209 from 2003/3/3
    If you're using an SBlive card with OSX and molk then that's pretty spectacular! Macs and SBLive cards don't get along well-at all-in a real hardware Mac environment. There are Live drivers for OS 9 but they aren't real spectacular. Creative specifically goes out of their way to NOT support OS X. Dunno why that is :-( I guess that's why M-Audio's cards are so favored in Mac land. Just as well, they're much better cards in the sound output department anyway.
    Has anyone tried the M-Audio sound cards with molk?
  • »14.03.08 - 17:39
    Frostwork
    Posts: 302 from 2003/4/18
    mol uses its own mol-audio driver - means audio is emulated, no matter which soundcard you use.
    using a real audio chip (ie no ac97) anyway increases quality
    a lot and reduces cpu-usage.
    there was some kind of "pci-card plugin" for mol which should
    have let you use some real pci-cards with native mac os drivers -
    no idea how useable it is/was though...
  • »14.03.08 - 18:33
