29th February bug
    Solo_Kazuki
    Posts: 182 from 2006/7/23
    Currently my system clock is set to 1st january 1985. Of course I'm not setting it myself - it's switched automatically.
    Is there anybody with similar bug?
  • »29.02.08 - 00:59
    Daff
    Posts: 250 from 2003/4/5
    Yep, it's a bug in MorphOS.
    I'm currently the 8th october 2007 :)
    http://obligement.free.fr
  • »29.02.08 - 02:04
    Black_Eagle
    Posts: 70 from 2003/6/5
    Yes, a bug. You can't even set the date to 29-feb-08. The 'date' command just outputs it's help text about syntax and won't accept 29 as a valid day.
    OnyxSoft - Amigans never surrender, they know they can do it better...
  • »29.02.08 - 04:58
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi all,
    yes this is an annyoing bug! I can't even read or print the mails I've sent with YAM, as they are simply not visible.
    Hopefully they will become visible tomorrow.
    Regards
    Christoph
  • »29.02.08 - 06:01
    Posts: 2213 from 2003/2/24
    October 10th, 2007 :) Btw. April has shown two 28th days for this month...
    [ Edited by jPV on 2008/2/29 10:21 ]
  • »29.02.08 - 06:19
    AmigaMancer
    Posts: 265 from 2005/8/25
    Same here. Is this a MOS-specific bug or does it exist in other OSes as well?
    Amiga 1200 user.
  • »29.02.08 - 16:18
