Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
tar/SFS and 4GB file limit?
JKD
# 1
Posts: 456 from 2003/4/4
Is there a filesize limit? tar keeps crapping out at around the 4GB limit..so I assume this is the case?
I've no idea where I got tar from..maybe it came with MOS?
EDIT: could be SFS I suppose
[ Edited by JKD on 2008/2/24 20:06 ]
25.02.08
04:03
# 2
MorphOS Developer
Posts: 1520 from 2003/2/24
There is 4GB size limit in MorphOS 1.4.x (it is actually 2GB, SFS stretches specifications).
25.02.08
11:19
mk
# 3
Posts: 72 from 2004/5/24
Yes.
At MorphOS 1.x (DOS) is the maximum Filesize 4GByte-1
and at SFS (for MorphOS 1.x) also.
Hint: Many old Programm have Limit <2GB and less.
The Filesystem ext2 for MorphOS can >4GB, but >4GB work only at MorphOS >= Version 2.x!
Split bigger Files (from /at another system) or
Wait of MorphOS 2.x.
25.02.08
11:28
