Robin Hood doesn't work with PowerSDL 11.14
    Daff
    Posts: 250 from 2003/4/5
    I've tried Robin Hood with the latest PowerSDL (11.14 here) and now Robin Hood doesn't work. There is only a black screen at the launch of the program.
    http://obligement.free.fr
  • »14.02.08 - 12:05
    Cego
    Posts: 738 from 2006/5/27
    almost the same problem here. it freezes when the intro screen appears. the mouse pointer appears and you can jump back to the ambient screen.
  • »14.02.08 - 16:30
    Posts: 108 from 2005/4/3
    The same problem i had with other programms, as Hatari and Madbomber. I solved it by editing the preferences again.
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »15.02.08 - 04:13
    analogkid
    Posts: 716 from 2004/11/3
    Airline Tycoon Deluxe seems to work, and better than before, because it doesn't hang on game-start and it even runs a little bit faster on my G3.
  • »15.02.08 - 05:53
    C64Days
    Posts: 103 from 2006/2/27
    Latest PowerSDL allowed me to finally compile programs like NeoPopSDL, on the other hand linking to SDL_ttf seems not to work anymore (but i could be wrong), Illka is abroad ATM,expect these issues to be fixed once he comes back to Finland.
  • »16.02.08 - 10:32
    Frostwork
    Posts: 302 from 2003/4/18
    yes, static libSDL_ttf.a is damaged in this release.
  • »16.02.08 - 11:02
    Posts: 1521 from 2003/2/24
    I check out Robin Hood issue.
    What linking error you get with libSDL_ttf.a ? I admit I did not try it out at all and cant remember what games are using SDL_ttf...
    Also, what SDL debug you are getting now? I checked sources and there should be no debug output left but probably something was not rebuilt due to dep issues.
  • »16.02.08 - 21:44
    C64Days
    I don't have it handy here but it's the usual undefined references to PowerSDL bla bla TTF... I wish i could take a longer look at it but i'm tight on schedule with other matters.
  • »17.02.08 - 12:45
