Tool like "Mounter" that works in MorphOS
    AmigaMancer
    Posts: 265 from 2005/8/25
    Hi.
    I'm looking for a tool that allows to mount partitions on demand. In AmigaOS 3.9, i'm using Mounter in a script to mount my browser cache partition, right before i launch the browser:
    sys:tools/mounter u=0 dh8: quiet
    c:addbuffers dh8: 200 quiet
    Aweb:aweb
    Mounter doesn't seem to work in MorphOS. Probably because it uses reaction, even if it doesn't open a GUI when used in command line.
    Amiga 1200 user.
  • »07.02.08 - 13:26
    analogkid
    Posts: 720 from 2004/11/3
    Maybe you want to try Giggledisk?
    http://www.geit.de/eng_giggledisk.html
  • »07.02.08 - 13:52
    dake
    Posts: 204 from 2007/9/14
    If you make or have a mountlist you can just use the command "Mount
    dh8:".
    And then if you want you can use "assign dh8: dismount" to get rid of
    the partion:)
  • »07.02.08 - 15:01
    AmigaMancer
    Thank you both.
    Amiga 1200 user.
  • »07.02.08 - 17:33
