MEncoder: 0.91 is unable to read a DVD which 1.0pre8 reads
    Posts: 423 from 2005/4/9
    @ CountRaven:
    you dont have to copy the codecs dir. from frogger to mplayer, in fact it is pointless. mplayer uses its own codecs which are hardcoded in the program (as i know).
    you can remove the froggercodecs from mplayer.
    there are several versions of mplyer out there for morphos (and for os4 which can be used on mos with os4emu i guess), try them all:))
    theres no media palyer with fancy gui on morphos.
    but theres some basic gui for mplyer. i currently use a mui one with stop/start/etc buttons, draggable slider and volume slider - just forgot the name right now. will check it for you.
    mplayer is the best mediaplayer right now on morphos. maybe some day we can run dvplayer (for os4) too.
    zx.spectrum@3.5
  • »18.12.07 - 09:34
    Korni
    Posts: 473 from 2006/2/23
    "MPlayer does NOT have a scroll / control bar with the play
    / pause / fwd buttons on it -or is it just my version-?"
    You have them in your mouse/keyboard :P. For movies i preffer MPlayer0.91. Dunno what exactly, but sth is wrong with MPlayer1.0 (even with some 0.91 releases), it has NO smooth playback. So, better use 0.91 if you can :-). Oldest (imho the best available ;-) ) 0.91 version is available from morph.zone, a bit newer 0.91 (to use with devedie gui with control bar etc. afaik it doesn't work with 1.0) by amirus is also here (when it comes to play DVD amiurs version suxx, it's a KaczusBB opinion because i don't have a DVD in my PegII :-) ).
    [ Edited by Korni on 2007/12/18 13:06 ]
  • »18.12.07 - 09:42
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    As previously said, MPlayer is controlled by mouse (use wheel to seek back and forth) and keyboard (cursor keys and many others, defined in conf/input.conf). The arexx port also allows some external GUI to control it with a slider or whatever.
    About 0.91 smoothness, i just tried on a few files (some panoramic scrolls) and can't really see a real difference, except that 0.91 doesn't have multibuffered display in overlay mode (which causes tearing and osd flicking). 0.91 is also much slower for some codecs (that were improved in ffmpeg since). One thing that sucks in 1.0 releases is the somewhat more laggy seek function.
    About dvplayer, i already tried it with os4emu, and even if it has a skin+slider, it was noticeably slower and didn't read many formats (and i don't think slowness could be attributed the the very low os4emu overhead).
    [ Edited by Fab on 2007/12/18 14:17 ]
  • »18.12.07 - 12:13
    "About dvplayer, i already tried it with os4emu"
    with which version of os4emu? my last info on this topic was that dvplayer isnt usable with the latest public os4emu, but with newer developer versions it is able to play and show videos.
    it has fewer codecs than mplyer but those os4 folks like it better. (dunno why, maybe because of the cool skins?:)
    anyway its funny to me that the only modern videoplayers on amiga-like systems are all by hungarian devs:))
    zx.spectrum@3.5
  • »18.12.07 - 12:40
  • Fab
    Fab
    Saddam,
    they like dvplayer better, because it has a gui and mplayer for os4 is not very stable nor fast and doesn't work in overlay modes (or only some of them on some cards depending on the moon phase). Native video (cgx_overlay, p96_whatever, cgx_wpa,..) & audio (ahi_*) mplayer drivers are buggy and it's even recommanded to use sdl ones instead (which doesn't help speed-wise). But you can try it in os4emu and see yourself anyway. :)
    [ Edited by Fab on 2007/12/18 14:52 ]
  • »18.12.07 - 12:51
    "But you can try it in os4emu and see yourself anyway. :)
    " - hahaha, i dont intend to:) im happy wiith the mos version, thanks to you:)
    but you havent answered my question: under wich version of os4emu you've played videos with dvplayer? please.
    zx.spectrum@3.5
  • »18.12.07 - 13:09
  • Fab
    Fab
    Sadddam,
    i probably used some unreleased version i guess. Tho it doesn't seem to work anymore, anyway. :)
  • »18.12.07 - 13:30
    Korni
    Try this http://www.uploading.com/files/RZBU7SJU/destfile.avi.html with https://morph.zone/downloads/MPlayer/MPlayer_0.91_MOS.lha and http://fabportnawak.free.fr/mplayer/MPlayer-1.0rc2.lha or other 1.0 :). Compare, have fun! :).
  • »18.12.07 - 15:07
    kriz
    Posts: 314 from 2005/10/18
    Mplayer rulez! Rock stable and plays all videos including .flv files ... Rocks!
  • »18.12.07 - 17:07
    Korni
    With -ao ahi_dev video playback is nicely smooth :).
  • »21.12.07 - 12:15
    Brumiga
    Posts: 276 from 2004/4/3
    Hello,
    Two years ago a friend gave me a cd with a movie encoded in realvideo 9 format. I tried to look it with current versions of mplayer in 2005, 0.91 and 1pre04, without success. Is now mplayer 1.0rc2-2.95.4 able to play realvideo movies or not ?
    Brumiga
  • »21.12.07 - 18:32
    CountRaven
    Posts: 566 from 2007/12/10
    Been back in here and I would like to THANK everyone for all the answers. Watching some cool video clips on my Peg is always big fan!!!!!
    [ Edited by CountRaven on 2008/1/26 3:05 ]
  • »26.01.08 - 01:03
