Netboot
    Levithicus
    Posts: 18 from 2007/12/18
    Have just bought a second hand Pegasos II and i wonder if it is possible to netboot it into morphos?
    Having looked around the net but the only thing i found is how to netboot linux on it. Put a cdrom in it but it doesnt work. It finds the drive but cant read anything from it.
  • »23.01.08 - 23:58
    Posts: 159 from 2003/10/24
    As far as I know you cannot netboot MOS. However I have run into times when my cd seems to contain nothing. When this happens I usually leave the disk in and power cycle the system. After that do an ls on the cdrom drive wait some time if it's blank (30 seconds or so) then ls it again and the directory usually comes up.
    --Mithalas
  • »24.01.08 - 19:55
