QuickGuide
    Korni
    Posts: 473 from 2006/2/23
    New version of my QuickGuide: http://www.kornl.ovh.org/files/QuickGuide.lha
  • »29.01.07 - 14:18
    Posts: 423 from 2005/4/9
    thx!
    but what are the changes from the prev. version?
    zx.spectrum@3.5
  • »29.01.07 - 20:00
    Korni
    Better keep previous versions to check that. I deleted them, so i don't remember all changes :)
    MCC_TheBar - new version, updated link
    http://fabportnawak.free.fr/misc/def-icons.lha - not availble now
    IB2.4, amissl3.6, songplayer, gerontolibrary, apooler, opus68k - added
    Ah. Watch out, there is an old 1.0 FryingPan listed instead of 1.1 :)
    [ Edited by Korni on 2007/1/30 0:00 ]
  • »29.01.07 - 20:59
    AmigaMancer
    Posts: 265 from 2005/8/25
    A useful guide. Thank you.
    Amiga 1200 user.
  • »30.01.07 - 12:26
    Korni
    Update :)
  • »02.04.07 - 12:50
    Korni
    Update :-)
    http://www.korni.ovh.org/files/QuickGuide.lha
    [ Edited by Korni on 2007/7/25 11:44 ]
  • »25.07.07 - 07:36
    r-tea
    Posts: 317 from 2005/3/27
    Heyah Korni!
    Did you ever thought to change the name of your guide to something more close to the subject?
    E.g. MOSQuickGuide or something?
    The plain name QuickGuide as is, can concern anything.
    [ Edited by r-tea on 2007/7/26 15:41 ]
  • »26.07.07 - 12:41
    Korni
    I did not. I don't think that name is really important here.
  • »26.07.07 - 15:41
    Korni
    http://www.korni.ovh.org/files/MorphGuide.lha
    Updated.
  • »03.09.07 - 19:16
    Sir_Lucas
    Posts: 112 from 2006/4/23
    Thx Korni for your work. This Guide is very helpful, indeed!
    Keep up the good work!!!!
  • »05.09.07 - 07:41
    analogkid
    Posts: 716 from 2004/11/3
    good work! There's a typo on P. 4 ("SHHCON"), and maybe you could add some more apps.
  • »06.09.07 - 03:24
    Korni
    http://www.korni.ovh.org/files/MorphGuide.lha is updated :-).
    [ Edited by Korni on 2007/10/9 11:12 ]
  • »09.10.07 - 08:05
    kriz
    Posts: 312 from 2005/10/18
    Thanks!
  • »09.10.07 - 09:22
    Phantom
    Posts: 381 from 2004/9/7
    MorphGuide. Now it's better ;-)
    Thanks!!!
  • »09.10.07 - 10:53
    r-tea
    There you go!
    You did it at last! :)
  • »09.10.07 - 18:17
    Korni
    Updated again...
  • »06.01.08 - 12:11
    Phantom
    Don't try to find it.... use the above link (2-3 threads before) as well... :-P
  • »07.01.08 - 22:26
