Problem with SimpleMail's preferences
    AmigaMancer
    Posts: 265 from 2005/8/25
    Hello.
    I have a problem with the preference window of SimpleMail. I believe it's MUI related.
    All the tabs are working ok, except of the "Accounts" one. When i click it, the window tries to resize itself and hangs immediately with a "Application is meditating" and the below Moslog window:
    00:12:59 24-Dec-07
    Exception 3 <Illegal Data Access at 0xfffffffc>
    Task 0x79124a48 <SimpleMail_MOS> Type 13 Pri 0
    SRR0 78e187e8 SRR1 0000f070 LR 78e109f0 CTR 78e10fdc CR 28002042 XER 00000000
    GPR[00] 78e109f0 79263bc0 79229550 00000000 8042679e 794e614a 0000121c 00000000
    GPR[08] 1100873c 00000000 11008748 79263c10 78c77e04 00000000 00000000 00000001
    GPR[16] 00000000 00000000 00000000 00000000 00000000 79267a98 79267a98 00000000
    GPR[24] 795b2bb4 ffffffff 00000001 79263c4c 78c77e04 794e611c 794e6058 794e5f4c
    SRR0 -> LIBS:mui/BetterString.mcc Hunk 1 Offset 0x99c8
    LR -> LIBS:mui/BetterString.mcc Hunk 1 Offset 0x1bd0
    CTR -> LIBS:mui/BetterString.mcc Hunk 1 Offset 0x21bc
    This problem is not confined to the latest MUI4 version. It also happens with older versions. I don't know about MUI 3.9 but who cares about that. I (believe) i have update all MUI classes to the latest versions.
    Does anyone else has this problem?
    PS: The log appears different each time. Now i got
    NList.mcc
    NList.mcc
    muimaster.library
    in place of BetterString.mcc (x3)
    [ Edited by AmigaMancer on 2008/1/4 10:14 ]
    Amiga 1200 user.
  • »04.01.08 - 05:52
    thefab
    Posts: 92 from 2003/8/19
    it could be related to the locale you are using ?
    i remember having some problem like this when doing bugged localization :p
    if you are not using the english builtin language, just try to rename the .po file related to your native language just to be sure.
    i just saw you have a 1200, it could also be related to your screen resolution beeing to small to fit the window itself, bad localization can make simplemail's window larger than screen on small config and then become very crashy.
    [ Edited by thefab on 2008/1/4 18:20 ]
  • »04.01.08 - 16:15
    AmigaMancer
    No, i'm not using any locale.
    Amiga 1200 user.
  • »05.01.08 - 00:34
