Posts: 568 from 2003/2/24
Hi td741,
@Spidey:
Are you going through the icon tooltypes or command line options? I just go through the tooltypes and I set the DVD_TITLE, DVD_DEVICE and DVD_UNIT. (Not 100% if those are the tooltypes since I'm not near my Pegasos at the moment. :P)
Well, I just installed mplayer and put its icon into a panel.
If I want to use it I just click its icon on the panel. When started I see the filerequester.
So as an answer I guess I use the tooltypes, but until now I haven't done anything with it.
It would be nice to be able to see a movie from start to end in one go
Spidey
