MPlayer Version 0.93 and 0.97
    Cego
    Posts: 733 from 2006/5/28
    Hey guys,
    i wanted to ask if someone could send me the above named Versions of MPlayer. I need them for testing DVD playback, cause it is quite slow and ansyncron on my Peg2 with G4@1GHz
  • »25.12.07 - 12:21
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Why don't you use 1.0rc2? libdvdcss in 1.0 version is a bit more compatible and cache is implemented in morphos version since 1.0rc1 or so, which makes it easier for slower drives (use -cache 16384).
  • »25.12.07 - 12:31
    Cego
    the last mplayer version doesnt play DVDs here on my system when i activate the cache option. i'm using TD Mplayer GUI and the output window is immediately disappearing right after i press on play.
  • »25.12.07 - 13:17
  • Fab
    Fab
    Don't use tdmplayer then and try to use the correct syntax. It should be mplayer -dvd-device ide.device:x dvd://1 -cache 16384 where x is your dvd unit. And I would be surprised it doesn't work, really.
    [ Edited by Fab on 2007/12/25 14:51 ]
  • »25.12.07 - 13:47
    Cego
    nope, it doesnt work, it freezes at the point where it should cahce.
    Cache fill: 0.00% (0 bytes)
  • »25.12.07 - 13:52
    Phantom
    Posts: 381 from 2004/9/7
    I use the last MPlayer, version 1.0 rc2 together with TDMPlayerGUI 0.10 and everything is fine here!
  • »25.12.07 - 14:18
    Framiga
    Posts: 363 from 2003/7/11
    Re: MPlayer Version 0.93 and 0.97
    by Cego on 2007/12/25 15:52:20
    have you copied the conf/ directory content as well?
  • »25.12.07 - 16:24
    Cego
    Of course i did.
  • »25.12.07 - 17:14
