registering morphos
    amiga4001
    Posts: 452 from 2006/11/16
    I try to send an email to support for registering but to no avail.
    I am in need for the latest release of morphos.
    I now have os 1.4.3 so not latest.
    Also can't get to the pegasosboek is this not available anymore?
    And this panelsthing in ambient are those some kind off docks like in amidock?
    Lot's off questions with my new toy..
    But nevertheless very pleased until now.
  • »24.11.06 - 05:21
    Posts: 109 from 2006/9/10
    You can't at the moment: Link
    "Due to holiday season all registrations done after October 13, 2006 are first processed after the Christmas Holidays 2006."
    I am basically in the same situation and trying to register Morphos Powerup using the registration server.
    In my case there isn't even a message on the website or a note when registrations will be possible again.
    The 2 hour-limit is getting rather annoying...
    :roll:
  • »24.11.06 - 05:46
    amiga4001
    Ah then I'll have to wait.
    But still strange that my emails ain't coming through.
    They are being bounced back.
    Is there server offline during this holiday?
    I now followed the link provided and filledin the form.
    So now I'll just have towait I guess.
    Hopeto have no problems with support for used peg.
    [ Edited by amiga4001 on 2006/11/24 8:15 ]
  • »24.11.06 - 06:10
    Chain-Q
    Posts: 350 from 2003/10/12
    Just to note this here, if you had registration attempts during the past months through support.morphos-team.net, but never received a reply, please register again. We had some lack of manpower, to process the registrations. This problem should be solved now. If you registered through october, november or december 2007, please check your e-mails, you should have received a reply.
    While you register, try to be sure, that you provide *CORRECT* information. Any sign of invalid information (that includes for example specifying invalid serial number intentionally) will result in refused registration attempt.
    Please note that the above does *NOT* apply to PowerUP registrations. PUP registrations were up and running, and all valid attempts were processed.
    Thank you. (On behalf of MorphOS Support Team)
    [.Hosting AmigaSpirit.hu.]
  • »15.12.07 - 21:20
    CountRaven
    Posts: 566 from 2007/12/10
    I think that we all should support MorphOS :)
  • »18.12.07 - 02:53
    Charvel
    Posts: 97 from 2007/2/15
    I will!
    As soon I can buy it for my Efika.
  • »18.12.07 - 03:43
