MOS 2.0
    TheMagicM
    Posts: 1220 from 2003/6/17
    Any real news (other than "when its done") ? Will it run on the new EFIKA?
    [ Edited by TheMagicM on 2007/10/23 11:56 ]
  • »16.10.07 - 18:58
    dIGIMAN
    Posts: 273 from 2005/11/7
    about mldonkey, its really difficult to set up, isnt it? is it the one with a browser-based gui or has a standalone gui?
    Well i think it was only to uncrunch and run it.
    Ofcourse you may adjust your firewall settings but thats the same for all.
    It has a browser based gui, which makes it real attractive for me.
    Whenever i have the idea (oh i need...) i can access it for example from work
  • »23.10.07 - 14:08
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Transmission isn't the best client to port. It doesn't respect protocol and is even banned from many trackers. I once made a quick'n'dirty transmission compilation which i never really released officially, because it tends to stall quite often.
  • »23.10.07 - 15:51
  • tom
    tom
    Posts: 149 from 2003/7/22
    Setting up Mldonkey is, even for me, very easy!!!
    I use it now for a long time. And yes sometimes it freezes so you have to start it again. But only MlDonkey freezes, not the computer.
    Regards Tom
  • »29.10.07 - 12:58
    Posts: 918 from 2004/1/24
    @tom
    Try setting "loop_delay" (downloads.ini) to 60
  • »29.10.07 - 13:49
  • tom
    tom
    I will try your advice. I had already increased it to 30
    Regards Tom
  • »30.10.07 - 14:47
    dIGIMAN
    Regards Tom
    I have 350 and still have this problem.
    I guess it depends how fast ur connection is :/
  • »31.10.07 - 12:16
    Wishmaster
    Posts: 342 from 2003/6/29
    [ Edited by Wishmaster on 2007/11/29 18:56 ]
    Pegasos PPC
  • »29.11.07 - 15:55
    MrZoon
    Posts: 48 from 2003/6/1
    Really? I'll buy it.
    MrZoon ~8
  • »06.12.07 - 14:27
    Chain-Q
    Posts: 350 from 2003/10/12
    Recent (0.9x) Transmission is said to be much closely following protocol, tho'.
    [.Hosting AmigaSpirit.hu.]
  • »08.12.07 - 10:01
