Same problem here, concerning the latest CVS version. But the version on Aminet works after putting back the "executable" flag on the two files "bochs" and "bximage".
The configuration is straight forward:
-First create a disk image file with bximage.
-Put the return values back in the ".bochsrc" configuration file
-Add your cddrive here too and you should be ready to go.
Example:
ata0-master: type=disk, path="media:pchd.img", mode=flat, cylinders=6095, heads=16, spt=63
ata0-slave: type=cdrom, path="ide.device 2", status=inserted
BTW: Does anyone know good values for
"vga_update_interval:" and "ips:"
for a PegasosII 7447/1000 MHz ?
Pegasos II/G4/512MB/Radeon9200
