    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 19.08.2011 - 15:57 ]
    Pegasos2 G3, 512 megs RAM
  • »15.11.07 - 19:41
    SoundSquare
    Posts: 1213 from 2004/12/1
    the rght forum for these questions is
    www.powerdeveloper.org
    there's an ubuntu section at powerdev
    now for your network issue, make sure you have DHCP enabled then edit the following file :
    /etc/network/interfaces
    as root (use sudo)
    sudo nano -w /etc/network/interfaces
    remove the # sign from the beginning of the last line, and execute
    /etc/init.d/network start
    and you're done.
  • »16.11.07 - 04:14
