Which Version Of War3D is MorphOS Using ???
    Sphinx_Ra
    Posts: 276 from 2003/3/14
    Hello,
    Anybody know this ???
    Because i got a lot of GFX Demo's (MAWI/Encore)
    and they are PPC/WarpOS, but most of them
    come with a window open and says:
    "This demo needs Warp3D 4.2 version or newer"
    :-x
  • »07.09.03 - 15:48
    Posts: 261 from 2003/3/13
    War3D is that a new war 3d game? ;-)
    No, seriously, sorry, i've put
    this question on the ML, hope
    ppl will respond..
    Bye,
    Felix.
  • »07.09.03 - 20:00
    bigfoot
    Posts: 510 from 2003/4/11
    Well, Goa emulates Warp3D V4.2.
    It's hard to know what the reason is without further info, the only thing I can think of right now is that you're using a graphicscard which doesn't have 3D support in MorphOS yet -- which one are you using ?
  • »08.09.03 - 16:18
    Sphinx_Ra
    WELL...
    That's not the problem, i use
    VooDoo3 2000, and my other Warp3D demo's
    does work fine , only not the latest demo's
    does not work
    :-x
  • »08.09.03 - 19:13
    bigfoot
    Mmm, if you could tell me the name of the demo, and where to download it, I could try it out here and see if it works.
  • »09.09.03 - 10:55
    Sphinx_Ra
    Oke, here's one of it:
    http://ppcdemodb.acggbg.org/files/Ppc-Encore+Scenic-Kheshkhash_WOS_CGX.lzx
    Good luck :-)
  • »09.09.03 - 15:19
    Henes
    Posts: 507 from 2003/6/14
    This demo uses a shell script as a launcher.
    Edit it and you will notice it checks if there are some specific
    files at some specific place on your disc.
    Checking for files this way is completly dumb and can fail... as you see :)
    It's completly irrelevant with Warp3D version emulated by MorphOS.
    All these checks should be done inside the demo executable, using
    standard OpenLibrary() call. There is no other system compliant way.
  • »09.09.03 - 15:44
    Sphinx_Ra
    Hmmmm... Oke Thanks :-)
    Learning every day... :-)
  • »09.09.03 - 16:08
    So disable the dumb lines with the library check with ';' before the centice
    Another W3D question, would W3d work with
    non Voodoo gfx board and the W3d CPU driver
    installed ? (Aminet)
    Felix.
  • »09.09.03 - 17:44
    Henes
    Sorry, there was a real problem. It's fixed for next release :)
    Anyway, this check is ugly. It would fail if a file was now resident
    (or was using some .elf extension).
  • »09.09.03 - 18:00
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    My english = 0/100... sorry :(
    Encore demos (PPC+3Dacc):
    1. New Age (Satellite 2000)
    2. Serial Interference (MekkaSymposium 2001)
    3. Plus (Symphony 2001)
    4. Kheshkhash (MekkaSymposium 2002)
    5. Sulaco (Abstract 2002)
    6. By Night (Symphony 2003)
    1, 2 = WarpOS+StormMESA+Warp3D 4.0+dbplayer
    3, 4 = WarpOS+StormMESA+Warp3D 4.2+dbplayer
    5, 6 = WarpOS+MiniGL+Warp3D 4.2+mpega
    1, 2, 3, 4 = NO Pegasos+Voodoo3, NO AmigaPPC+Voodoo3, YES AmigaPPC+BVision
    5, 6 = YES Pegasos+Voodoo3, YES AmigaPPC+Voodoo3, YES AmigaPPC+BVision
    Sulaco realtime - Pegasos+3D OK:
    ftp://ftp.scene.org/pub/parties/2002/abstract02/amiga/demo/enc_sulaco-ok.lha
    ByNight realtime - Pegasos+3D OK:
    ftp://ftp.scene.org/pub/parties/2003/symphony03/amiga/demo/encore_bynight.lha
    Sulaco DivX - Pegasos OK:
    ftp://ftp.scene.org/pub/parties/2002/abstract02/amiga/demo/encore_sulaco.avi
    ByNight DivX - Pegasos OK:
    ftp://ftp.scene.org/pub/parties/2003/symphony03/amiga/demo/encore_bynight.avi
    Kheshkhash_fix for Voodoo3 - future... :)
    Bye bye bye;)
    MDW/Encore
    english... sorry... :(
  • »09.09.03 - 18:27
