bug(s) in mos mount command
    zukow
    Posts: 662 from 2005/2/9
    @MosTEAM,
    Official mount command from morphos CD doesn't mount mountlist made by giggledisk for standard dos partition (mount from amigaos 3.x works ok). For example BlockSize in morphos mount command has SizeBlock readargs template which is wrong (correct is BlockSize).
    Could you fix this?
    [ Edited by zukow on 2007/11/3 20:28 ]
  • »03.11.07 - 17:27
    Posts: 919 from 2004/1/24
    You could try Sonic's unofficial update:
    http://aminet.net/util/cli/Mount-MorphOS.lha
  • »03.11.07 - 20:16
