Time settings in Main Preferences
  • tom
    tom
    Posts: 149 from 2003/7/22
    I can't adjust the time in the main preferences....
    'Error!!! Couldn't use the preference class'
    I've the latest Ambient (nightly build) and the latest MUI-update. What's going wrong?
    Regards Tom
  • »03.11.07 - 14:35
    Chain-Q
    Posts: 350 from 2003/10/12
    Latest MUI beta (which on the first place is not meant to be used on 1.4.x, it's just no one stops people doing so:) contains a Clock.mcc, which is incompatible with 1.4.5 Prefs application. Use a Clock.mcc which came with your 1.4.5 installation, or with any earlier MUI beta.
    [.Hosting AmigaSpirit.hu.]
  • »03.11.07 - 15:17
  • tom
    tom
    Thanks, that was the trick.
    But I didn't know that Mui4 was only developed for Morphos.2.0. I will be carefull with up-dating from now on. But I like the new Windows with its features......
    Regards tom
  • »03.11.07 - 16:21
