SFS Defrag for Shell?
    dIGIMAN
    Posts: 273 from 2005/11/7
    Hey dudes,
    i am searching for a SFS Defrag Tool, which i can use
    in my scripts, to defrag over night or when the load is low...
    I am using the old 68k sfsdefrag atm,
    but im not really happy as it still has a window
    output, which cant be suppressed.
    I havent found alternatives myself.
    Maybe there exsist a AROS Backport or so, i dont know about?
  • »29.10.07 - 20:16
    Brumiga
    Posts: 276 from 2004/4/3
    @dIGIMAN,
    You can use sfscheck in a cli, it is native ppc. I use it so :
    sfscheck dh0: seek purge fraglist defragment
    Brumiga
  • »30.10.07 - 06:06
    dIGIMAN
    Brumiga wrote:
    @dIGIMAN,
    Brumiga
    Thanks, didnt notice that one.
    Seems to work, to bad there is also a output window,
    which cant be killed
  • »31.10.07 - 09:24
