Converting from 24bit .iff to 8bit
    amiga4001
    Posts: 454 from 2006/11/16
    Which program is best with peg2 to convert from 24bits to 8bits(256 colour)?
    I tried PPaint which seems to do a nice job but messes with system.
    Like I can't open aminetradio after Ppaint running(can not open render.library).
    After reset it is just fine again.
    Is showgirls not able to do so?
    I also tried with adpro..Execute and then render to raw and save as 256colour but quality is very poor.
    Ppaint does a much much better job.
    It even lokks like adpro isn't using all 256 colours.
  • »11.10.07 - 03:40
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 12.09.2011 - 09:01 ]
    Pegasos2 G3, 512 megs RAM
  • »11.10.07 - 07:39
    Wishmaster
    Posts: 342 from 2003/6/29
    The best Tool for true colour to 256 colour conversion is Xv.
    Try if you can get that one running.
    Pegasos PPC
  • »11.10.07 - 10:18
    amiga4001
    Thanks for the tips!
    I am using this gfxcon ..good results.I like it very much.
    It is easy and fast enough for my needs.
    Will look into this Xv also.
  • »11.10.07 - 18:27
    analogkid
    Posts: 722 from 2004/11/3
    I like SView5 very much, it has many options and some operators are MorphOS-native.
  • »11.10.07 - 18:43
    tokai
    Posts: 1289 from 2003/2/25
    ImageFX has nice color reducution algorithms. It was a bit difficult to use, but the results were pretty good. But it's a commercial software, dunno if its still possible to buy it after all.
  • »14.10.07 - 01:07
