New MUI Beta 10.06.2007
    Posts: 1087 from 2003/3/24
    A new MUI Beta is available.
  • »07.10.07 - 07:28
    Framiga
    Posts: 363 from 2003/7/11
    ouch! thanks luky-amiga, i didn't notice it.
    Pity that he didn't removed the crap debug/error output, from some MUI apps.
  • »07.10.07 - 12:30
    Gelb
    Posts: 148 from 2003/3/4
    Are you complaining about debug output of a non public beta version or about the lack of Stefan to remove debug output from MUI apps he has no control of?
    Both make no sense.
  • »07.10.07 - 13:14
    Framiga
    5/0.System3.9:C> sashimi
    Sashimi installed ([Ctrl]+C or "Break 5" to remove)
    0000000000000000MUIP_AskMinMax: bogus: min=-8/15 def=-8/15 max=10067/15 for obj=0x099da860(udata=0)(Group.mui)In Arrivo
    0000000000000000MUIP_AskMinMax: bogus: min=-8/19 def=-8/19 max=10000/19 for obj=0x09451c88(udata=0)(Group.mui)
    00000000000000000MUI_LayoutObj: obj=0x0940ae38(udata=0)(Image.mui)0x0 10152/10329 8x8 failed completely (min=0x0 max=0x0)
    00000000000000000MUI_LayoutObj: obj=0x094e3ce0(udata=0)(Image.mui)0x0 10697/10329 8x8 failed completely (min=0x0 max=0x0)
    00000000000000MUIP_ShowClipped: obj=0x0940ae38(udata=0)(Image.mui)0x0 <- no previous MUIM_Layout
    00000000000000MUIP_ShowClipped: obj=0x094e3ce0(udata=0)(Image.mui)0x0 <- no previous MUIM_Layout
    you decide then!
  • »07.10.07 - 13:21
    BeNZo
    Posts: 18 from 2007/10/7
    Hi to all!
    It's my first post here, but I follow you since some months.
    The new "framed groups" color settings
    (MUI Prefs -> Group -> Framed Groups -> Color)
    don't works here with this MUI beta (10-6-2007)
    and the gauge.mui seems to be visibly slower..
    Please delete this account.
  • »07.10.07 - 13:41
    Gelb
    @framiga
    Well, you are using a beta version. Live with debug output or install latest public version. I can't really understand what you are complaining about.
  • »07.10.07 - 15:52
    Framiga
    Gelb wrote:
    @framiga
    if you "can't understand" its your fault, not mine.
  • »07.10.07 - 16:20
    warface
    Posts: 653 from 2003/2/24
    I think debug output is an intentional "side effect" of it being a beta. Presumably for more precise and detailed feedback purposes.
  • »07.10.07 - 18:48
    Posts: 3327 from 2003/3/5
    The debug output is there to point out bugs in applications or MUI classes. For example the layout debug above comes from NList bugs.
  • »08.10.07 - 04:23
    Framiga
    Thank you both for your kind replies.
    Is the enviroment "muidebug" switch actually working?
  • »08.10.07 - 09:48
    As far as I remember this kind of debug is not conditional. Better whine to people really resposible for it - that is, the autors of apps/classes.
  • »08.10.07 - 09:55
    Framiga
    effetively that debug output, affects only apps using NList (no prob with IBrowse and Sputnik f.e).
    I've tryed everything to avoid the huge slowsdown under MOS for PowerUP (above all using YAMdev) but the only solution was to stick this line in User-Startup:
    run >NIL: sashimi
    No way to redirect that debug in ramdebug. (at least i didn't find any)
  • »08.10.07 - 10:12
    kiero
    Posts: 129 from 2003/2/28
    yes, "muidebug" switch is working, and you can enable more debug with it.
  • »08.10.07 - 11:19
    Gelb
    @framiga
    Well, if you don't know what beta versions are, don't use them and quit whining.
  • »08.10.07 - 11:26
    Phantom
    Posts: 381 from 2004/9/7
    @Gelb & Framiga
    You are both fantastic... hahaha :-P
  • »09.10.07 - 10:47
