Slow internet connection with MosNet
    Phantom
    Posts: 381 from 2004/9/7
    I use internet a few weeks now with MOSNet, but as far I can see my
    internet connection is slow according when I use internet with my
    f***pc. Is there any setting I can change?
  • »27.09.07 - 02:17
    Jupp3
    Posts: 1193 from 2003/2/24
    Some versions of MOSnet had some russian domain in one settings file in db/ directory (which means, that when you try to access f.ex. morph.zone, it will first try to access morph.zone.whatever.ru, which of course doesn't exist, but will slow down considerably)
    Just remove that, and it should be faster.
  • »27.09.07 - 10:09
