Looking for an m4a player or converter
    wlamee
    Posts: 59 from 2004/2/18
    Hey all,
    As the subject says, are there any m4a players available or ways of converting m4a to MP3 (or something else that is supported) for MorphOS?
    Wouter Lamee
    mailto:wouter@wouterlamee.nl
    http://www.wouterlamee.nl
  • »22.09.07 - 16:35
  • tom
    tom
    Posts: 149 from 2003/7/22
    Ik vond dit op internet:
    De FAQman: De extensie 'M4A' hoort bij het bestandsformaat 'MPEG-4 Audio Layer'. Een andere extensie voor dit formaat is 'ALE' en dat is dan weer de afkorting van 'Apple Lossless Encoder'. Achter het internetadres 'www.mp3-cd-converter.com' vindt u de tool 'AltoMP3 Gold' en daarmee converteert u (onder andere) M4A-bestanden naar MP3-bestanden (zie afbeelding) . En met MP3-bestanden kunt u alle kanten op!
    VLC kan hier trouwens ook mee overweg.
    Heb je Mplayer al geprobeerd? Die speelt heel veel af.....
    Groetjes Tom Overtoom
  • »22.09.07 - 18:00
    wlamee
    Tom,
    I know m4a is MPEG-4 Audio, and my versions of Mplayer (v0.91 'butterfly edition' as well as 1.0pre4 and 1.0pre7) don't play the m4a files I have (radio 538 dance department podcasts in this case, any of them). Or is there a newer Mplayer out that does do this? If so, where is it?
    I also know there's plenty of Windows s/w that can handle m4a files, but I'm looking for MOS versions only (otherwise I'd have used the PC version or posted this Q on a PC forum if I still couldn't find it). Or is there a MOS compile of VLC that I missed out on?
    Wouter Lamee
  • »22.09.07 - 18:44
    AKiLL
    Posts: 93 from 2006/3/6
    wlamee wrote:
    Tom,
    Try this version of MPlayer
    Maybe you'll manage to play that file format...
    Bye,
    AKiLL
  • »23.09.07 - 05:38
    jcmarcos
    Posts: 1178 from 2003/3/13
    http://media-convert.com
    Amazing.
  • »24.09.07 - 07:05
    AmigaMancer
    Posts: 265 from 2005/8/25
    Amazing indeed. The only problem is that the URL function doesn't seem to work with any Amiga browsers and even sputnik.
    You have to upload the file that you want to convert and this is not good for ppl with a slow connection. Does anyone know a similar service with a working "fetch url" function?
    Amiga 1200 user.
  • »24.09.07 - 15:37
    wlamee
    Nice one there, thanks for a link to a newer MPlayer, that one seems to have slipped by me. But it doesn't do it either, the command line shows it's not supported, as it's trying to use the MPEG-2 layer 3 decoder and ends up with:
    ISO: File Type Major Brand: Apple iTunes AAC-LC Audio
    Seek failed
    MOV: missing data (mdat) chunk! Maybe broken file...
    MPEG-PS file format detected.
    MPEG: FATAL: EOF while searching for sequence header.
    Video: Cannot read properties.
    Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
    ADecoder init failed :(
    Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
    Unknown/missing audio format -> no sound
    Opening audio decoder: [libmad] libmad mpeg audio decoder
    Cannot sync MAD frame
    Opening audio decoder: [hwmpa] MPEG audio pass-through (fake decoder)
    Cannot sync MPA frame: 0
    Cannot find codec for audio format 0x50.
    Read DOCS/HTML/en/codecs.html!
    Audio: no sound
    Video: no video
    So still no m4a player ...
    Wouter Lamee
  • »24.09.07 - 17:20
    Posts: 98 from 2004/6/4
    Try ffmpeg from www.amirus.org.ru/files.html
    I don't remember if I compiled in mp4a support there or not, but I suppose that I did.
    WBR, Vladimir Berezenko
  • »25.09.07 - 02:39
    jcmarcos
    I've posted somethig about this in the Sputnik bug thread.
  • »25.09.07 - 05:08
