MomosIRC - new IRC client for Morphos
    MaaG
    Posts: 86 from 2003/7/22
    Hello,
    You can download new IRC client for Morphos - MomosIRC.
    It need more work, but now is working, and (as i think) better get binary than next screenshots ;).
    Binary get from here
    More details [polish] here
    Have a fun.
    Author.
  • »21.07.07 - 14:04
    Posts: 2198 from 2003/2/24
    Looks very nice client. Add couple of features and it will be really usable :)
  • »21.07.07 - 15:21
    keropi
    Posts: 131 from 2006/11/11
    nice one!!!! Thanks!  :-)  :-)  :-)
    A4000D CS-PPC/G-Rex4000D
    A4000D CS-PPC/Zorro
  • »21.07.07 - 17:46
    Chain-Q
    Posts: 350 from 2003/10/12
    Nice work! Thanks! I love it. However, it still miss a few small features to make me move away from the good(?) old AmIRC. First and biggest one is timestamps. The second is proper nicklist sorting (ops first). And to support more commands if possible. (ie. it said it doesn't know server or connect command, when i tried to connect to a 2nd server.) These are the minor ones... There are major ones as well, but you're probably know about them anyway... :)
    But i really love it. Keep working on it!
    [.Hosting AmigaSpirit.hu.]
  • »22.07.07 - 06:21
    MaaG
    /server command currently dosn't suppor, but you can add more servers into network config window .. and wait for next (beta) version of MomosIRC  :-)
  • »22.07.07 - 08:26
    analogkid
    Posts: 710 from 2004/11/3
    It looks very promising, and I like the GUI much more than WookieChat's one.
    Hope you can complete your client soon, in the meantime AmIRC will do the job ;)
  • »22.07.07 - 08:56
    diezi7
    Posts: 167 from 2005/7/25
    Thanks very much maag.
    It's a nice IRC client.
    Where did you get the name for the program, and does it mean something?
    I like the interface. It fails when connecting to my usual servers, but others work fine.
    Seems like a very promising alternative for relay chat, and even maybe the first native MOS IRC client, isn't it?
    Any planned features for the future? :-)
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »22.07.07 - 17:04
    VooDoo
    Posts: 189 from 2005/8/24
    Nice IRC client...I test in on MOS Pup and is to slow? dont know why..slow connection to server..slow listing user's on channel..all is slow? dont know why? is ppc native?? wookie and AmiRC have perfect speed!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »24.07.07 - 17:38
    tokai
    Posts: 1289 from 2003/2/25
    some style guide cleanup here and there... more options etc. and you have a solid IRC client for everyday usage.
    But please use Lamp.mcc for the admin/ voice light bubbles. This current images are ***ugly. ;) Lamp.mcc is part of MorphOS 2.0, so it's safe to use.</featureleak>
    (afair you can still download a bit older versions of MorphOS lamp.mcc from zeroheros MUI page: http://www.zerohero.se/mui/download.html)
    regards,
    tokai
  • »24.07.07 - 19:15
    tokai
    @diezi7:
    nope, thats not correct. There are various ports of epic around already (one even on my homepage: http://www.christianrosentreter.com/releases/tuxgoesmorphos.php ). Also AmIRC is known to exists as MorphOS native version, but wasn't released to public yet for some reasons, see: http://www.biclodon.com/software/amirc/.
    [ Edited by tokai on 2007/7/24 22:20 ]
  • »24.07.07 - 19:19
    Kamul
    Posts: 121 from 2004/6/9
    And what about WookieChat? It seems to be quite MorphOS native since
    19th May 2007.
  • »25.07.07 - 04:26
    diezi7
    Hi Christian
    True, It's ppc native, but it comes out from another platform.
    I've downloaded and will take a look at epic, hope it's
    not too complicated being console based :-)
    Unfortunately it still does not exists for me. It's a mere html doc with a jpg image . It could reach out from the dustbin someday, who knows.
    BTW, very nice work on Shuffle MOS. :-o
  • »25.07.07 - 04:50
    tokai
    @kamul:
    indeed. How could I forget this. :) The more IRC clients the better... a little bit competition will improve the quality of the products.
    @diezi7:
    Dunno if epic is complicated... if you like console it might be even more comfortable than a GUI-based one ;). It has an issue I couldn't figure out yet (must be MorphOS ixemul.librray related). One has to 'su' to another user (e.g. 'su root') to get it's colors working properly. The default users shell only supports b/w for some reason. But else it seems fully functional. Well.. and it needs a fully installed GG:-environment (everyone should have anyway ;) )
    and thx. for the shuffle flowers. ;)
    [ Edited by tokai on 2007/7/25 10:59 ]
  • »25.07.07 - 07:59
    Fransexy
    Posts: 25 from 2005/9/14
    Really we need another IRC client?
    There are another types of apps that there are no equivalent on our platform
  • »25.07.07 - 20:10
    AmigaMancer
    Posts: 265 from 2005/8/25
    But they are more complicated and harder to code?
    Amiga 1200 user.
  • »25.07.07 - 20:27
    diezi7
    Hi Tokai
    Hummm, I remember MLDonkey docs stated that too, is it only a recomendation or a must have?
    I don't have GG installed :). Let?s try
  • »27.07.07 - 04:10
    MaaG
    Small MomosIRC update:
    - now working TAB-key (with one small bug - it will be fixed soon ),
    - fixed some bugs with connections...
    Download it from the same link as prevous... (download link)
  • »19.08.07 - 10:04
    MaaG
    I like Greek mithology.. and (as before Nemesis desktop) see Momos (or Momus) then.
  • »19.08.07 - 20:29
    Get27
    Posts: 90 from 2004/8/23
    @Tokai :
    hello, why amirc port is private ?
    is it a part of Morphos 2.0 ?
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »19.08.07 - 23:56
