Ibrowse + Fast Connections (again)
    dIGIMAN
    Posts: 273 from 2005/11/7
    Hi people,
    i wanted to ask for a few Ibrowse Hints with MOS again,
    after i found out a few things.
    After my ADSLv2 Modem broke, were i had 16mbit, and i put back the ADSLv1 Modem in the meanwhile, giving me about 6 mbit, my ibrowse ran much better.
    I atleast could use it, were it normally nearly always crashed eg. aminet/pegasosforum.de, everywhere were alot of small icons been loaded.
    Isnt there any way to avoid this? Seems like this may could be fixed, playing around with taskpris?
    I tried serval other stuff like, changing the max network connections to 1, using prefs from other peoples and so on. When i using my ADSLv2 Modem, ibrowse is not usable for me... :/
    Well it still crashes with 6mbit but i dont wont to go slower :)
  • »06.08.07 - 22:56
    Framiga
    Posts: 363 from 2003/7/11
    how many connection opened in IB Networks?
    I'm on Alice20 Mega (adsl2+) (16-17 Mb actually)
    Edit- and what TCP/IP stack? send/receive buffers?
    [ Edited by Framiga on 2007/8/7 12:05 ]
  • »07.08.07 - 12:04
    dIGIMAN
    Thanks for your reply.
    So u have no problems with fast connections?
    Could you try to open up www.pegasosforum.de for a few times?
    I use genesis. Infact amitcp only, i dont touch the genesis gui and use my own startscript:
    MBUF_CONF Initial = 2
    MBUF_CONF Chunk = 64
    MBUF_CONF ClChunk = 4
    MBUF_CONF MaxMem = 8096
    MBUF_CONF ClusterSize = 2048
    TCP_SendSpace = 32200
    TCP_RecvSpace = 32200
    Its always the IbrowseNetwork Task that crashes (ramdebuglog)
    For a while i had it to 1 Connection maximum, in the settings. But this doesnt save me from crashing.
    I also noticed, that the same sites, that crashed ibrowse (lots of small objects/connections need) also crashed aweb sometimes.
    When Voyager worked nice (pre MUI 4) i never had this problem. It seems like Voyager was faster and could handle all this data.
    Also ibrowse worked nice on my A4K but i guess the machine didnt serve the data so fast to ibrowse (10mbit/68060 etc)....
    Well, maybe its just playing around with taskpris or putting a delay (somewhere) or using uae :)
  • »07.08.07 - 16:11
    Framiga
    no, i have no problems at all!
    PRIORITY = 5
    MBUF_CONF MaxMem = 2048
    TCP_SendSpace = 32768
    TCP_RecvSpace = 32768
    Max number of connections=10 (more is a wast IMHO)
    Max. numb. of secure conn:= 4
    Max simultaneus connections=unlimited (feel free to limit them to 4-8)
    NO diskbased cache (or take it in T:)
    Mem cache
    Images=8192
    Pages=4096
    Good luck!
  • »07.08.07 - 16:39
    dIGIMAN
    PRIORITY = 5
    Maybe its this point.
    Strange, i know alot that have the same problem like me. Well....
  • »07.08.07 - 17:15
