Posts: 2217 from 2003/2/24
At some point there was partition size table in SFS changelog:
--clip--
EDIT: DON'T TRUST THESE! :)
The current partition size limits of SFS are:
64 GB with 512 bytes/block
128 GB with 1024 bytes/block
256 GB with 2048 bytes/block
512 GB with 4096 bytes/block
1 TB with 8192 bytes/block
2 TB with 16384 and 32768 bytes/block
--clap--
It's also said, that unless you need very big partition, the best values for block size are 512-2048 for speed/space effciency.
I recently bought 320GB WD3200JB drive for my Pegasos1 and partitioned it with partitions under 128GB each, just to be sure they're not too big. I used 1024 bytes blocksizes for most partitions and 2048 for biggest (which also has big files only).
First I partitioned all space I saw with SCSIConfig. Then I started to install Debian and noticed that Linux partitioner shows more free space than I was expecting. I found that SCSIConfig has a limit with detecting the disk size. Then I used SCSIConfig to change drive geometry to values what Linux said and got all the space available to MorphOS side too. It has worked so far, but maybe somebody with more expertise could tell if it is safe :)
I have pretty many partitions now. Partly because I found that extra space and partly because I didn't want too big partitions either :)
Here's mounted partitions in MOS, you can calculate the overall space and add couple of gigs for linux/bootimages partitions ;)
dh0: 616.0M 203.4M 412.5M 33% 0 read/write SFS Boot
dh1: 2.0G 664.1M 1.3G 33% 0 read/write SFS Utils
dh2: 1015.9M 704.3M 311.6M 69% 0 read/write SFS Temp
dh3: 20.0G 13.9G 6.1G 69% 0 read/write SFS Fun
dh4: 100.0G 75.5G 24.5G 75% 0 read/write SFS Store
dh5: 120.0G 117.3G 2.7G 98% 0 read/write SFS Movies
dh6: 7.9G 4.9G 3.0G 62% 0 read/write SFS Work
dh7: 964.6M 106.6M 858.0M 11% 0 read/write PFS3 TestLab
dh8: 37.9G 27.3G 10.6G 72% 0 read/write PFS3 Store2
Edit: and I have MOS 1.4.5...
[ Edited by jPV on 2007/8/2 12:32 ]
[ Edited by jPV on 2007/8/2 17:56 ]
