I need to repair my MOS partition, but how with SFSDoctor?
    AmigaMancer
    Posts: 265 from 2005/8/25
    Hi.
    My MOS partition became corrupted for the first time since i started to use it. It boots but when the Ambient screen opens, nothing happens when i click to icons.
    So, i re-installed MOS with SFSDoctor v1.1 on another partition and i'm trying to repair the damaged one.
    I start SFSDoctor, select "Check disk" and here is the log:
    --------- START
    Welcome to SFSDoctor - The Disk Recovery and Repair Suite
    [22:34:49] Checking drive DH3:
    [22:34:49] Checking root blocks
    [22:34:49] Okay
    [22:34:50] Checking admin space containers
    [22:34:52] Okay
    [22:34:52] Checking node containers
    [22:34:52] Error: container at block 1755 doesn't contain node 17 (nc 26)
    [22:34:52] Error: container at block 1755 doesn't contain node 112 (nc 574)
    [22:34:52] Error: container at block 1755 doesn't contain node 126 (nc 574)
    [22:34:52] Error: container at block 911 doesn't contain node 1452 (nc 1756)
    [22:34:52] Error: container at block 911 doesn't contain node 2088 (nc 1234)
    [22:34:52] Error: container at block 911 doesn't contain node 2342 (nc 1284)
    [22:34:52] Error: container at block 911 doesn't contain node 2350 (nc 1284)
    [22:34:52] Error: container at block 910 doesn't contain node 2351 (nc 1284)
    [22:34:52] Error: container at block 910 doesn't contain node 2352 (nc 1284)
    [22:34:52] There are errors in filesystem structure. It is advised to backup data and repair this partition
    [22:35:11] Saving activity log to file Gift:check.log
    ------------- END
    "... repair this partition"? Where is the repair option? I suppose it's the "scan disk" option?
    I click on the "scan disk", but it starts to display some messages and then SFSDoctor quits itself!! No time to save the log or anything! It just quits like if i pressed the close gadget.
    Bummer.. I need some help.
    ** EDIT **
    I just remembered that "scan disk" always used to self-quit or even hang even when i was trying to scan a good partition for testing purposes.
    [ Edited by AmigaMancer on 2007/7/30 1:36 ]
    Amiga 1200 user.
  • »29.07.07 - 17:40
    AmigaMancer
    And here is what SFSCheck says:
    Partition start offset : 0x00000001:7C804800 End offset : 0x00000001:BD55B000
    Surfaces : 1 Blocks/Track : 332
    Bytes/Block : 512 Sectors/Block : 1
    Total blocks : 2124468 Size : 1037,3MB/0,0MB (99%)
    Device interface : TD64 Version : 1.210
    Device buffers : 128 Device caches : 16x32768 (524288 bytes) [CPB]
    Checking RootBlocks
    ...okay
    Checking Config Block at block 2124466
    ...okay
    Checking AdminSpaceContainers at block 2
    ...okay
    Checking NodeContainers at block 7
    ObjectContainer at block 1755 doesn't contain node 17.
    ...damaged
    Amiga 1200 user.
  • »29.07.07 - 17:43
    Kamul
    Posts: 121 from 2004/6/9
    I suggest you to try to contact with March (author of SFSDoctor). When
    this program was in beta stage, I have some problems with it a
    few times. March was always helping me immediately. The only problem
    is he could be on his holyday now.
  • »30.07.07 - 06:43
    Posts: 2213 from 2003/2/24
    Easiest (and maybe the fastest) repair is to back up files to other location and quick format the partition and copy them back :)
  • »30.07.07 - 08:16
    Kamul
    Right. But if you don't report the bug, it will still be there. :)
    And one time a partition whose size is enough to make some troubles to
    back it up could get broken.
  • »30.07.07 - 10:24
    AmigaMancer
    @Kamul
    Good idea. I will send him a PM and see.
    @jPV
    The problem is that the system doesn't let me to copy some of the files from the damaged partition. I suppose that a program like SFSDoctor could be able to repair the partition and make this files accessible again.
    Amiga 1200 user.
  • »30.07.07 - 15:43
    VooDoo
    Posts: 189 from 2005/8/24
    Before two months I try repair damaged sfs partition whit SFS Doctor v1.1 but no luck  :-( .. aftre this boot OS3.9 and using RDB-Salv...whit this progy copy all files to other partition...and after that qucik format Quote:
    AmigaMancer wrote:
    @Kamul
    @jPV
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »30.07.07 - 16:12
    Jupp3
    Posts: 1193 from 2003/2/24
    If I remember correctly, there was some separate "recover lost files" option in sfssalv. To same or different partition. Of course I would recommend "different partition"
    Directories, for which location/name is lost, will be put in lost+found.
    I have had problems with SFS on MorphOS once, and I managed to rescue lost directories with SFSSalv, but for many of them, the directory name was lost.
  • »31.07.07 - 03:50
    AmigaMancer
    @Jupp3
    I don't have any lost directories or files. Just some files which are there but i get errors when i try to copy them.
    Anyway, your suggestion to use SFSSalv was good! I was able to salvage these files to another partition. Thank you.
    Amiga 1200 user.
  • »31.07.07 - 17:01
    MarK
    Posts: 641 from 2004/1/25
    hey!
    get a new round cable!!! i also got strange errors while copying, and hdd was okay, only the 80line cable was corrupted...
    bye, MarK.
  • »01.08.07 - 02:14
    Kamul
    I wouldn't say rounded cables are better than the flat ones,
    especially in case of little power consuming Pegasos. But, for sure,
    it must be a 80 wire cable, and of course not broken one. ;)
  • »01.08.07 - 07:57
