Program for "Synchronizing" drawers?
    winterhunter
    Posts: 204 from 2005/10/13
    Hi everyone,
    I've just bought an USB external HD that I plan to use to keep a
    backup of all my multimedia (mostly pics) that currently resides on my
    pegasos.
    Is there some utility to backup/synchronize the new files/drawers to
    the HD? I'd rather use something that just copies the new/updated
    files since I have around 40 GB of pics, and it takes AGES to copy
    them all.
    Thanks!
  • »22.07.07 - 09:40
    catohagen
    Posts: 297 from 2003/5/20
    copy Media:pics/#? backup:media/pics/ all DONTOVERWRITE
  • »22.07.07 - 11:25
    dIGIMAN
    Posts: 273 from 2005/11/7
    them all.
    RSYNC for MOS would be cool.
    If you have linux, you can use it.
    It does a pretty good job, has mirror/diffcopy function and so on.
  • »22.07.07 - 17:02
    Posts: 2217 from 2003/2/24
    I've used UpDateCopy from Aminet... It's otherwise nice, but I'd also like similar program, which would delete the removed/renamed files too.. now the backup just grows :)
  • »23.07.07 - 16:17
    dIGIMAN
    jPV wrote:
    ..I'd also like similar program, which would delete the removed/renamed files too.. now the backup just grows :)
    Well, maybe somebody really should do RSYNC then.
    Its a command line tool, so it shouldnt be to hard for somebody who knows what he is doing (not me :) )
  • »23.07.07 - 17:59
    Gelb
    Posts: 148 from 2003/3/4
    There is also MirrorCopy, which I use myself and which works quite nicely.
    ---snip---
    The main features of MirrorCopy are:
    - The destination directory will contain exactly the same files
    and subdirectories as the source directory - and nothing more!
    - The attributes (date, comment and protection flags) of the
    files and subdirectories in the destination directory are set
    exactly to the same values as in the source directory.
    - MirrorCopy takes care of what the destination directory allready
    contains:
    - only those files are copied, that need to be copied.
    - only those subdirectories are created, that need to be created
    - only those files and subdirectories are removed from the
    destination directory, that need to be removed.
    This is very usefull if you don't want to create a mirror copy,
    but if you want to update an allready existing mirror copy.
    - MirrorCopy can keep deleted or overwritten files in special
    'deleted-/old-files' directories.
    - The contents of the source directory is not changed in any way!
    Not even the protection flags (like the archive flag) are changed.
  • »24.07.07 - 04:22
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    I use FolderSync for several years now and it works fine for doing an daily update of my backup disk.
  • »25.07.07 - 05:49
    dIGIMAN
    ---snip---
    contains:
    If nothing is changed on doing a mirror, does the tool really notice if something is altered on the source hd? Mhh sounds a bit strange to me
  • »27.07.07 - 10:11
