SuperBase Pro
    xray
    Posts: 21 from 2003/4/30
    Any suggest (information and experiences) about intallation of SuperBase Pro 4.x under MorphOS?
    Thank you
  • »15.07.07 - 12:52
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    I installed it many years ago (SuperBase Pro V 1.30i) and it ran. (Well... actually I simply copied the SuperBase directory from my Amiga 4000 to the Pegasos II, and the SBase.ini file from Workbench:S to SYS:S on the Pegasos)
    It still appears to run fine today with all the updates to MorphOS that appeared since then (but I admit that I never used SuperBase extensively and/or with complex databases in the last two years).
  • »15.07.07 - 15:37
    matt3
    Posts: 785 from 2004/2/10
    I copied over from my 3k and it runs fine.
    The only issue is that the entry screen for data do not refresh properly. If I remember correctly, you can't place a window over the entry one or the screen won't refresh. I think the query/reporting didn't refresh either.
    I switched to muibase, it works cleaner under MOS.
    Take care,
    Matt
  • »15.07.07 - 21:38
    xray
    @DoctorMorbius_FP
    I have make the same thing!
    @Matt
    I have exactly the same problem. It was also to recover the data from SBPro!
    (MUIBase) yes, my to, but I will recover my data from SBPro:-)
    Thanks
    xray
  • »16.07.07 - 05:15
