How can I snapshot the "Select File" requesters?
    keropi
    Posts: 131 from 2006/11/11
    Is there any way at all to snapshot these windows? I tried to open their MUI settings and press SAVE but they revert to default... I also tried in Ambient Settings to make the windows posistion stored permanently, but it does not work either...
    I get that ackward size in these windows, I am bothered to always resize them and their listers. I don't like them like that.  :-P
    is there any tip for that? thanks !  :-)
    A4000D CS-PPC/G-Rex4000D
    A4000D CS-PPC/Zorro
  • »12.07.07 - 05:31
    Posts: 2204 from 2003/2/24
    I still use original asl.library from MOS install cd.. not that MUI4 version (that's my small tip ;) But doesn't that menu-gadget on top right corner have the usual snapshot function?
  • »12.07.07 - 06:20
    keropi
    no, it only has iconify / jump to screen / MUI settings and About MUI ... no snapshot on these requesters...
    how can I revert to original ASL.LIBRARY?
    A4000D CS-PPC/Zorro
  • »12.07.07 - 07:17
    Posts: 423 from 2005/4/9
    "How can I snapshot the "Select File" requesters?" - wait for mui4 final:)
    as far as i know you cant do it right now with this mui version (you also cannot load mui settings).
    zx.spectrum@3.5
  • »12.07.07 - 09:01
    keropi
    @sadddam:
    lo, it is good to know, thanks for clarifying this
    A4000D CS-PPC/Zorro
  • »12.07.07 - 09:12
    "how can I revert to original ASL.LIBRARY?"
    Copy asl.library from the 1.4.5 CD (or dig it from sys:.recycled if it's still there after mui4 installation) to mossys:libs/
  • »12.07.07 - 09:34
    amiga4001
    Posts: 454 from 2006/11/16
    Use magicasl from the aminet.
    It's superb,great etc.. and snaphots..
  • »12.07.07 - 18:14
