undelete sfs files
    amiga4001
    Posts: 452 from 2006/11/16
    I deleted some files which I really would like to recover.
    There should be a recycled folder with deleted files?
    Where?When show all in that partition nothing shows up.
    Also tried sfsdoctor but only seems to be possible to recover complete partition?
    Help!
  • »10.07.07 - 03:23
    mobydick
    Posts: 179 from 2004/2/26
    The partition (SFS) should be formatted with "recycle" and "show recycle" modes enabled. After format you will see the catalog named ".recycled".
    Mmmm... As far I remember, ypu can choose files you want to recover...
    peguser.narod.ru
  • »10.07.07 - 03:57
    MarK
    Posts: 641 from 2004/1/25
    well, with only 'recycle' enabled, the directory will be generated in the root directory, it just won't be visible. but if you enter it manually, you will get there. that's the simpliest way to 'undelete' your recently deleted files.
    bye, MarK.
  • »10.07.07 - 04:05
    antibike
    Posts: 112 from 2003/3/5
    correct spelling of the undelete folder is ".recycled".
    here a example: "Sys:.recycled/"
    of course the partition must be formated with the Recycle feature switched on in the past.
    (ups this was allready written :-))
    [ Edited by antibike on 2007/7/10 8:51 ]
  • »10.07.07 - 05:48
    Framiga
    Posts: 363 from 2003/7/11
    SFSFormat always create a ".recycled".
    If you don't want it, you have to add the option NORECYCLED.
  • »10.07.07 - 11:02
