Fxpaint problems with libraries?
    amiga4001
    Posts: 454 from 2006/11/16
    I am using FXpaint so now and then.
    But it won't work properly anymore.
    It takes a very long time to start up (loading pens...) about 15 seconds..
    ANd the textbrush doesn't want to work anymore.
    It's gui works allright and I can choose a font but it just won't create a textbrush.
    ALreay removed some libs of the OS4.0 emu stuff which helped a bit as before Fxpaint was freezing when applying textbrush.
    ANy idea's which does this?
  • »07.07.07 - 18:24
    CISC
    Posts: 619 from 2005/8/27
    If removing os4emu libs help I'd say your problem is os4emu (or rather, the LoadSeg patch, which is known to fubar a few things)...
    - CISC
  • »07.07.07 - 18:38
    amiga4001
    Where is this patch situated and how to remove it completely?
    Just guessing it is OS4.0 emu..
  • »07.07.07 - 19:08
    Toto
    Posts: 268 from 2003/4/20
    Check s:user-startup for "C:PatchLoadSegOS4 >NIL:" and remove it.
    ~toto
    [ Edited by Toto on 2007/7/8 1:52 ]
  • »07.07.07 - 22:48
    amiga4001
    It didn't work because off a faulty brush or pen it tried to load on startup.
    After deletion off all my brushes/pens it starts up nicely and my textbrush works again.
    Hooray.
  • »08.07.07 - 17:38
    Daff
    Posts: 251 from 2003/4/5
    If loading pens is long, try to delete them in the menu "windows -> brush manager", and relaunch FxPaint.
    http://obligement.free.fr
  • »08.07.07 - 20:36
    amiga4001
    Thanks for the tip.
    But deleting them in the dir is much faster.
    You can't select multiple files in the brushmanager?
    Or can you?
  • »09.07.07 - 18:09
    Daff
    No, you can select only one brush at a time.
  • »09.07.07 - 19:44
