UAE for MOS section
    Coder
    Posts: 296 from 2003/3/5
    I allready mentioned before that I was going to put a UAE for MOS section on my site. With FAQ, manuals, what games does work and what not etc. I have not completed that all but there is allready a forum section and a FAQ section. I thought I would say this here because there are really a lot of UAE related threads wich might be a bit to much for some people.
    Check out www.flyingpaper.com
    Any help on this would be great. To more info about it the better.
    Coder
  • »31.08.03 - 22:30
  • Targhan
    Posts: 2833 from 2003/2/8
    Don't forget to submit your link to the MWD!
    :idea:Targhan
  • »01.09.03 - 07:16
    Coder
    @Targhan
    I will make sure I do that.
    I hope to have more UAE for MOS related things up there in the coming weeks. First up will be a manual how to install it. If people here think they can contribute something related to UAE for MOS be my guest. :-)
    Coder
  • »01.09.03 - 09:20
    Spidey
    Posts: 568 from 2003/2/24
    Hi Coder,
    Do you have to register to your site to see the faq concerning UAE? :-)
    Spidey
    ps: I just registered, will login this evening when I'm home.
  • »01.09.03 - 11:57
    Coder
    Hi Spidey,
    At the moment yes, but if people like to be able to see it without logging in I can change that. So far only 1 FAQ is in it which I got from here.
    Coder
  • »01.09.03 - 12:06
    Coder
    The forums are being used so have a look there. Any help is welcome. What I think is really needed is a list of the features of the current UAE for MorphOS. Anyone willing to help out on that?
    Furthermore (nothing to do with UAE) I will have a interview up there with Attention Software (working on MOS software) and my review about my Pegasos (small not indepth) board.
    Coder
  • »02.09.03 - 10:16
