Do you feel the cold? [BurnIt3]
    analogkid
    Posts: 716 from 2004/11/3
    If I got it correctly, it's impossible to use 4 gb files in an Amiga-like environment.
    [ Edited by analogkid on 2007/6/16 12:07 ]
  • »16.06.07 - 10:06
    BatteMan
    Posts: 290 from 2003/2/24
    analogkid : open your eyes...
    The file was on a samba mounted partition on MorphOS
  • »16.06.07 - 13:23
    r-tea
    Posts: 317 from 2005/3/27
    @ dIGIMAN
    To change this, it would require alot of changes to the dos.library and FS i guess (like SFS2 tries)
    AFAIK there is no problem with SFS or any other FS under MOS. The only one problem is the problem with dos.library
    [ Edited by r-tea on 2007/6/16 21:56 ]
  • »16.06.07 - 18:56
    CISC
    Posts: 619 from 2005/8/27
    Actually the problem is a threefold one; DOS, FS and App.
    DOS: needs new 64bit API
    FS: needs new 64bit packets (and be able to manage the data correctly)
    App: needs to use the new 64bit API
    ..until all of the above is solved everywhere you'll have issues...
    - CISC
  • »17.06.07 - 06:47
    catohagen
    Posts: 297 from 2003/5/20
    just got a mail from Vesalia
    "We're sorry, due to quarrels between Dns and Titan BurnIt 3 was revoked and must not be sold anymore - thus we won't be able to deliver, so we decided to drop the product from our shop and refund all orders."
  • »22.06.07 - 14:35
    magnetic
    Posts: 2129 from 2003/3/1
    wtf?
  • »22.06.07 - 15:08
  • mk
    mk
    Posts: 72 from 2004/5/24
    > catohagen on 2007/6/22 17:35:19
    I have talked with Vesalia (Mr. Does, Owner and managing director):
    1. There is no quarrels between the involved ones.
    2. Vesalia has several versions of BurnIt!3 are present.
    3. When desired of Mr. Siegel (private reasons of Mr. Siegel, other persons are not involved in it) however none of these versions is to be delivered.
    4. It is not a speech of it, which is not to be sold the product anymore.
    5. Vesalia is located in contact with Mr. Siegel around the question for the distribution of BurnIt!3 to clarify.
    6. (Without confirmation of order) transferred amounts are back transferred hastily by Vesalia.
    7. The product not far away from the shop, but the status is at present changed: "call"
    [ Edited by mk on 2007/6/23 19:39 ]
  • »23.06.07 - 15:48
    Framiga
    Posts: 363 from 2003/7/11
    how many Vesalia are there? :-?
  • »23.06.07 - 16:01
    analogkid
    mk, our living babelfish ;)
  • »23.06.07 - 16:23
