Migrating from Ambient 1.42 to latest nightly build
    winterhunter
    Posts: 204 from 2005/10/13
    Dear all,
    I've installed the latest nightly build of Ambient, and I have the following issues with it:
    + Filetype scripts no longer run (even though they are still there in the same directory).
    + def_xxx icons do not work.
    How do I get these things to work?
    Thanks a lot!
  • »14.05.07 - 16:15
    Korni
    Posts: 473 from 2006/2/23
    http://www.korni.ovh.org/files/QuickGuide.lha
    Some basics about Ambient installation ;-)
    [ Edited by Korni on 2007/5/14 19:53 ]
  • »14.05.07 - 16:53
  • mk
    mk
    Posts: 72 from 2004/5/24
    http://morphosambient.sourceforge.net/dl/Filetypes20061027.lha
    This Filetypes Paket (with Installer, Backup, VoodooX Version2 and much more) work also at last ambient (Mai 2007).
    Hint: If necessary then adjusting Paths for your installed applications in WBStartup/FileTypesPath with a Texteditor!
    [ Edited by mk on 2007/5/15 7:22 ]
  • »15.05.07 - 04:10
    winterhunter
    Thanks a lot!
    For the filetypes, it "looks" a bit clearer (even though I would have GLADLY kept my old ones).
    I will look into the guide to see how to fix the stuff with the deficons (what was changed between versions?).
  • »15.05.07 - 14:38
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    First, i don't even remember "1.42" had filetype support, but whatever.
    In the meantime, I think filetypes path changed from mossys:ambient/filetypes/ to sys:prefs/ambient/filetypes. But anyway, now you shouldn't even bother about that since there's a filetype gui where you can adjust both actions and deficons (to add a deficon, you just drop your favorite icon on icon area in the filetype editor window).
    About deficons, the naming scheme is more elaborated than old "workbench" def_<extension>.info thing. As an exemple, the icon associated to video/x-avi mimetype will be <deficon path>/video/x-avi.info.
    If x-avi.info doesn't exist, then video/default.info would be tried and if it's still not found, then it would be <deficon path>/default.info or so.
    This is much better than relying only on extension.
  • »15.05.07 - 15:09
    catohagen
    Posts: 297 from 2003/5/20
    where did you find this may build ? ambient page lists
    a nightly build from 1 april 2007..
  • »15.05.07 - 15:52
  • mk
    mk
    > catohagen on 2007/5/15 18:52:54
    > where did you find this may build ? ambient page lists a nightly build from 1 april 2007..
    Read the Quickguide.pdf linked here from Korni, Site 1 at the bottom. "Geit is offering a non debug Version..."
  • »16.05.07 - 03:59
  • DDJ
    DDJ
    Posts: 99 from 2003/2/23
    Hi, the server is down for some days now, someone here can tell us if this is temporary or we lost this source too?:-?
    never mind, its up now :-P.
    [ Edited by DDJ on 2007/6/11 12:25 ]
    [ Edited by DDJ on 2007/6/11 14:05 ]
    Peg2 G4 1Ghz rev. 1.2 - CPU rev 1.2 - Built on 20050808
    OF-version 1.2 (20050808153840)
    Radeon 9250 (9200Pro) 256MB/128bits AGP - OEM PCVIEW (ProLink)
    RAM 1GB - 2x512MB DDR333 CL2 - Kingston HyperX
    40GB ATA100 - Brand ?
  • »11.06.07 - 13:21
    stephen_robinson
    Posts: 746 from 2007/4/22
    Okey, I give up, how do you open the .tgz files? I've tried untgz ambient.tgz but it says
    UnTGZ: File "ambient.tgz" is either not a gzip file or
    not in a gzip format that UnTGZ can handle!
    UnTGZ: Operation failed
    but itjust tried it with another file, and that decompressed fine, what's going on!?
  • »17.06.07 - 20:14
    stephen_robinson
    Typical, I downloaded it again, for the 4th time, and err... it worked!
    Oopse!Sooryy!
  • »17.06.07 - 20:25
