HD-Rec And Sweeper & Midi
  • JPQ
    Posts: 5 from 2004/6/17
    HD-Rec dosent play anything with midi or sweepper. What is wrong ?  :-(  :-(
  • »07.06.07 - 20:43
    imax
    Posts: 41 from 2004/9/20
    It should do it ?
    Use timidity (68K) or AmiNetRadio with gerontolibrary for playing MIDI.
    What is sweepper ?
  • »08.06.07 - 10:14
  • JPQ
    I need Midi sequencer not Midi player.:( Sweeper is softsynth form Hd-rec archive.
  • »08.06.07 - 14:58
    Pasi
    Posts: 3 from 2007/6/8
    Have you enabled midi in Preferences/MIDI and selected midi ports?
    I have these settings for SBLive:
    Port #0:
    in: emu10kx.in.0
    out: emu10kx.out.0
  • »08.06.07 - 18:34
  • JPQ
    Pasi: i have same settings last time i tested it dosent work but i try again. Nothing changed but Bars&Pipes work but this B&P version is little buggy....
    [ Edited by JPQ on 2007/6/8 23:11 ]
  • »08.06.07 - 18:57
    Tomo
    Posts: 94 from 2003/7/29
    For heavy midi-use I still use my Amiga. I have the same problem with midi on my Peg. Sometimes B&P works and sometimes it chrashes suddenly or it refuse to save the file.
    Tom
  • »10.06.07 - 08:49
    Pasi
    HD-Rec is running very nice on my PegII without any problems
    with MIDI. Maybe it's the driver versions ?
    I have these versions:
    Devs/MIDI/emu10kx V5.5
    Devs/AHI/emu10kx.audio V6.6
    Devs/ahi.device V6.6
    Libs/camd.library V40.5
    HD-Rec V0.9u
    [ Edited by Pasi on 2007/6/10 18:41 ]
  • »10.06.07 - 14:24
  • JPQ
    I have
    Libs/camd.library V40.4
    Devs/ahi.device V6.2
    HD-Rec V0.9w Beta (10.06.2006)
    how i get never versions ?
    ja jos pasi kuten nimimerkist? oletan tai joku muu ymm?rt?? suomea tarkoitan ett? mist? l?ytyisi nuo uudemmat versiot.
  • »10.06.07 - 16:02
    Pasi
    You can find it here:
    camd.device - follow the link from HD-Rec download page
    (www.hd-rec.de)
    ahi.device - ppc-morphos-ahiusr.lha (aminet)
  • »10.06.07 - 18:27
