fat95 with MOS possible?
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    Does someone know, if fat95 is working under
    MOS? Would be great to have one "allround"
    partition containing f.e. mp3s for MOS, Linux and
    MOL....
    bye
    frostwork
  • »30.08.03 - 12:04
    serge
    Posts: 725 from 2003/2/20
    hi
    I'm using Fat95 for USB floppies and zips.
    Never try it with a partition, but I think it works.
  • »30.08.03 - 12:35
    Frostwork
    Hi, serge!
    Thanks for answer!
    Here fat works good with USB-stick and camera, too...
    But I fail trying to make a fat HD.... :(
    bye
    frostwork
  • »30.08.03 - 15:44
  • Targhan
    Posts: 2833 from 2003/2/8
    Same story here, I'm afraid. I use it with Zip drives, pendrives, but haven't tried it with a partition yet.
    :idea:Targhan
  • »30.08.03 - 16:05
    DSLCC
    Posts: 246 from 2003/5/14
    Same results here....I use it for my pendrive and it works great there...should try it with a hard drive... :-?
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »31.08.03 - 00:55
    td741
    Posts: 224 from 2003/4/2
    I was trying to salvage some things from FAT16 and FAT32 formated drives/partitions from my dead PC.
    I downloaded MountDos from Aminet, configured it to use Fat95. Plopped the drive in my system, and *poof*, it mounted the partitions found on my PC drive. It worked with my 10gig and 2 gig harddrives. My 20gig reported some read errors when trying to mount it so I'm unsure if it's a Fat95 bug or bad blocks?
    Steph
  • »31.08.03 - 04:28
    Posts: 12 from 2003/8/7
    Yes, i use it with USB-Sticks / USB-HDD-Drives with
    FAT32-format (size is 40 GByte) or MP3-HDD-players!
    No problems at all!
    Bye
  • »31.08.03 - 12:41
    Frostwork
    Hi!
    Maybe Poseidons massstorage.device tells our Peggies
    to use fat95. But MOS probably doesn't ?
    But I'll try MountDOS!!!! ;)
    Thank you all for the hints!!!!
    have a nice day
    frostwork
  • »31.08.03 - 13:57
    td741
    When you use mount dos, you'll need to edit the tooltips.
    There's a FAT95 tooltip that's disabled by default, a "Mount" tooltip that will mount the partitions found. There is also a tooltip for the device and unit. So, for IDE you'll need to write: ide.device as the device and unit 0-3 depending where the drive is plugged in (0 = primary master, 1 = primary slave, 2 - secondary master, 3 - secondary slave).
    Steph
  • »31.08.03 - 17:50
    Frostwork
    Hi td741!
    I tried it at home, but I only get shell opening, telling me that my ide.device Unit 0 has 4 partitions,
    which are all empty.... (120GB -> maybe to big?)
    I have 10 partitions on it.....
    Thank you anyway!!!!!
    If it doesn't work I'll continue coping files from
    FFS to HFS via linux (PegXLin CD can read both and
    even SFS, but MOL crashes in the Rev1 state of the CD : so I have MOL running on an extra
    "original" debian woody rc1).
    Please don't ask, where I got the CD from, ask david
    via email or visit his website....
    bye
    frostwork
  • »31.08.03 - 21:33
