Recommended CD Burning Tool.
    matt3
    Posts: 784 from 2004/2/10
    I have a projected that I have to copy multiple audio cd's and I thought my peg 2 would get a good workout instead of using the PC.
    What program do you recommend for copying audio cd's?
    I have 2 cd drives in my peg 2, so I will be going cd to cd.
    Thanks for the feedback,
    Matt
  • »01.06.07 - 23:48
  • mk
    mk
    Posts: 72 from 2004/5/24
    MakeCD is the best.
    And its free since 03/2007. The unrestricted License Key is found at followed Page:
    http://makecd.core.de/
    Hint: For Copy use MakeCD over CopyCD Icon.
  • »02.06.07 - 04:25
    SoundSquare
    Posts: 1214 from 2004/12/1
    Frying Pan is not free but is far more modern.
    Works like a charm here.
  • »02.06.07 - 07:41
    matt3
    Thanks so much for the help.
    I tried putting in the registration code in make cd and it claims it's invalid. Any ideas?
  • »02.06.07 - 16:06
    Framiga
    Posts: 363 from 2003/7/11
    after to type the code, hit return and fill the other string until the Save option goes un-ghosted.
  • »02.06.07 - 16:48
