Regarding the new MOS2.0 early startup menu
    Posts: 2730 from 2003/2/24
    Just a question to anyone who may know. Here you can see pictures of the new MorphOS 2.0 early startup menu:
    http://www.geit.de/eng_geitmeeting25052007.html
    What can you really do in it?
    How "early" is it; is it possible to set serialdebug/ramdebug etc?
  • »29.05.07 - 09:02
    Posts: 3327 from 2003/3/5
    The features are similar to AmigaOS3.x bootmenu. You can also "force" the Ambient screenmode to something most monitors should be able to display in case you're swapping the display.
    Ramdebug/serial debug starts immediately after you boot It's there waaaay before you get to bootmenu.
  • »29.05.07 - 09:36
    @jacadcaps
    Thanks! :-)
  • »29.05.07 - 11:21
    Tronman
    Posts: 209 from 2003/3/3
    Howdy!
    Just wanted to say thanks for the link with all the pics, it's nice to put faces to some of the names, and also see actual humans using MOS 2.0 and OS 4 :-)
    Makes me wish I were European sometimes!
  • »30.05.07 - 16:39
    boot_wb
    Posts: 874 from 2007/4/9
    Excellent gallery!
    Looked like a good night.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »30.05.07 - 16:54
    wolfe
    Posts: 118 from 2003/8/7
    I like that work center table . .  8-)
    Looks like everyone was having fun . . good to see . . . :-D
  • »31.05.07 - 09:45
