AmiTradeCenter hangs when using ANY drive other than RAM:
    winterhunter
    Posts: 204 from 2005/10/13
    I have just run across a very weird problem concerning AmiTradeCenter
    v1.1308:
    When downloading (or uploading) any file, and the local drive is not
    RAM: (I've tried ALL local drives, FFS and SFS formatted) ATC just
    hangs after transfering like 50 kB or something.
    This happens but when the remote computer is in the local net as in
    the internet.
    Any ideas why and/or workarounds? I need to backup 8 Gb of pictures,
    and having to do it by "batches" (copy to RAM:, then transfer, erase,
    start all over again) is going to drive me nuts.
    Thanks!
  • »19.05.07 - 23:33
    Jupp3
    Posts: 1193 from 2003/2/24
    v1.1308
    Is that the newest version of the program?
    Becouse many people reported that the newest version had some problems, including being way more unstabile, I never bothered updating to it.
  • »20.05.07 - 09:17
    Framiga
    Posts: 363 from 2003/7/11
    i got in the past that kind of problem with ATC and MOS for PowerUP.
    I've fixed it renaming the "PROGDIR:Libs/e-utils.library.elf" to "e-utils.library".
    The other one (the 68K) to e-utils.library_68K.
  • »20.05.07 - 11:24
    winterhunter
    @Framiga: It seems that the problem is not the same here, I've tried
    renaming both files and nothing changes.
    @Jupp: Could you please check which version you are using?
  • »21.05.07 - 16:40
