Posts: 265 from 2005/8/25
Hi.
As my Amiga is not powerful enough to play most of the AVI codec movies, i'm trying to convert them to MPGs which is a format my Amiga can easily handle with only some minimal frame skip.
I have major and very annoying problem with this though..:
The mpg converted movies are played with the audio being out of sync with the video! For example, i see someone moving his mouth and after some seconds i hear him talking...
What i have observed is that the MPGs which i produce with mencoder are being played without any frame-skipping whatsoever. Even if this is _absolutely_ required in order to achieve audio/video synchronization.
I even did this test. I run a very cpu consuming task and then i tried to play these MPGs: Not even one frame was skipped. I'm not sure if this is the source of the problem, but i know that this isn't normal! I mean, when i play movies which were originally encoded as MPGs from the beginning, i do get some frame-skipping and the audio/video sync is PERFECT!
As you can see in this link:
http://www.amiga.org/modules/newbb/viewtopic.php?topic_id=32576&forum=9
i've also tried to do the same proccess using FFmpeg and got similar problems like with mencoder!
What could i possibly be doing wrong?!
Please help.
[ Edited by AmigaMancer on 2007/4/30 11:37 ]
Amiga 1200 user.
