Easy networking between peg and amiga1200
    amiga4001
    Posts: 454 from 2006/11/16
    What is the easiest solution to transfer files from peg to amiga1200.
    Through ethernet that is.
    Don't really care about fastest just easy to setup..
  • »03.05.07 - 17:54
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    Set your Pegasos as a FTP site with RC-FTPd and use DOpus Magellan or AmiTradeCenter on the A1200.
    The average speed is up to 5 Mbytes/sec (peak speeds are higher) on my LAN between Pegasos (with MiamiDX), A4000, and two PC's.
    You can find useful instructions in "The Pegasos Book".
  • »03.05.07 - 18:18
    amiga4001
    That's a neat idea.
    I'll give that a go...thanks
  • »03.05.07 - 18:32
    magnetic
    Posts: 2129 from 2003/3/1
    Well the best thing would be to use Envoy 3. Its an Amiga networking solution and is fantastic
    magnetic
  • »03.05.07 - 19:31
    Posts: 2213 from 2003/2/24
    If you're using AmiTCP (Genesis), then the absolutely easiest is using amiganet-filesystem, which is installed by default with amitcp. You can mount other Amiga's any partition with netmount command from cli.
    Here's also small security risk. If you're connected directly to internet (no router or port blocking) other people might mount your drives too :) So any amitcp user should check his configuration and disable amiganetfs completely if not needed or make .nomount file on each partition you don't want to share. But it's also nice practical joke to put some funny files on other people's ram disk for example.. done that couple of times in past ;) They learned to configure their stack...
  • »05.05.07 - 04:44
