AmIRC issue
    GK_LKA
    Posts: 481 from 2004/3/28
    Ave!
    Please help me, this thing makes me absolutely crazy: I use two AmIRC's at the same time, the first always starts when I boot and connects to a BitlBee server (and through this server to MSN and ICQ). The other client is for regular IRC - but, sometimes if I want to start the client it says that "Cannot open vapor_toolkit.library". It is definetly where it should be, because the other client is still running.
    The problem came some months ago, before that point I never got this message. There aren't any new programs installed (except the newer versions of YAM nightly, Ambient, and maybe the trance update).
    Another thing what you should know is that when the problem appears, if I write "avail flush" into console, the whole system hangs.
    Please help me locating the bug...
    [ GK / LKA Team ]
  • »21.04.07 - 13:55
    BatteMan
    Posts: 290 from 2003/2/24
    Did you launch Sputnik before this message ? I have it sometimes too... But don't know why...
  • »21.04.07 - 14:24
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    It looks like something is corrupting heavily your system (memlist trashed, or even worse).
    You should have a look at your debuglog when it happens and especially when you can hang system with avail flush, to locate the culprit.
  • »21.04.07 - 14:44
    GK_LKA
    No, I didn't. I use only IBrowse, AmIRC, SongPlayer, YAM and only a few other programs...
    If the problem comes again, I will post my debug log here.
    [ GK / LKA Team ]
  • »22.04.07 - 19:38
