Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
Ghostscript 8.13 for MorphOS
Schlonz
# 1
Posts: 131 from 2004/4/16
Hi all,
I am searching the MorphOS-native version of Ghostscript 8.13. The original link
http://www.whoosh777.pwp.blueyonder.co.uk/gs_morphos_noixemul.lha
does not work anymore, and whoosh did not answer to my emails yet.
Anyone know where I could get it, or would anyone of you be so kind and send it to me?
11.08.05
17:22
Brumiga
# 2
Posts: 268 from 2004/4/3
Hello Schlonz,
At http://www.whoosh777.pwp.blueyonder.co.uk/index.html#install you can download Ghostscript 8.50 files and 68020 no-fpu binary.
Brumiga
12.08.05
06:56
Schlonz
# 3
I know that I can download the 68k-Version, which does work very well. But I would like to try out the MOS-native version.
But meanwhile I could get it by a friendly person on IRC.
12.08.05
18:04
deb
# 4
Posts: 76 from 2004/11/17
You can download Ghostscript 8.13 MorphOS-native version at
http://www.pegasosforum.de/dload.php?action=file&file_id=494
15.08.05
20:07
Sonic
# 5
Posts: 408 from 2004/7/15
Just wanted to get it and discovered that the link is dead again.
May be someone should place this file here, on MorphZone? Or on Aminet?
iPod, iBook, iMac,... iRobot?
10.04.07
05:41
rms
# 6
Posts: 606 from 2004/11/27
just an info, as far as the tests I've done with programmer of GS the native MOS version is not stable at all you better stick to the latest 8.54 68k no-fpu version.
Regards
Christoph
11.04.07
06:30
