Speedup showing pictures
    amiga4001
    Posts: 454 from 2006/11/16
    I am not that surprised by the speed off showing pictures off my dig camera on my peg.
    Pictures are on harddisk so not slow usb 1.1
    It takes about as much time to load a 2 MB picture(jpeg) and show it as on my amiga4000 with cybppc.
    I am using showgirls for displaying.
    Haven't installed any datatypes or something like that.
    Should I..Do they exist?
    Or an other way to speed up things.
  • »08.04.07 - 17:54
    imax
    Posts: 41 from 2004/9/20
    Try use mijfif
  • »09.04.07 - 09:41
    Korni
    Posts: 473 from 2006/2/23
    mjfif has troubles with big files :-/
    Maybe SG is making a thumbs, that's why it takes much time? Send me this JPG. I wanna try! :P Try mysticview or picshow. They are a bit faster than ShowGirls.
    [ Edited by Korni on 2007/4/9 14:57 ]
  • »09.04.07 - 11:54
    imax
    Last versin work correct.
    At case size >4000x3000 Cybergraphics return WRONG DATA. But this system problem, not mijfif.
    Try use 16bit screenmode
  • »10.04.07 - 05:37
    Korni
    I use 16bit screenmode :) Anyway, it isn't big trouble because i don't have many big jpgs, and they works ok with other picture viewers :-)
  • »10.04.07 - 08:12
    analogkid
    Posts: 706 from 2004/11/3
    I like PicShow very much, it preloads pictures while showing some other pics, and it's fast in showing too.
  • »10.04.07 - 08:29
    imax
    Go to private. Send me link of example to imax9 AT narod DOT ru
  • »10.04.07 - 08:52
