WookieChat available for MorphOS
    jahc
    Posts: 24 from 2004/2/8
    I've downloaded Amidevcpp and gotten a ton of help from freenode #morphos, and after 3 days I've got a working binary made for MorphOS!
    Download the full package:
    http://aminet.net/comm/irc/wookiechat2_5.lha
    Then grab this MOS executable + latest catalogs, and copy it to where you've installed WookieChat:
    http://wookiechat.amigarevolution.com/wookiechat/beta/
    I hope it works okay, but knowing my luck it probably wont. :) Check it out!
    P.S. For those who dont know, WookieChat is a program that allows you to connect to Internet Relay Chat networks (IRC!) and chat with other users in a text medium in real-time. Some of the server groups are preconfigured to join an Amiga chat channel upon sucessful connection.
  • »07.04.07 - 01:20
    mdma
    Posts: 85 from 2003/5/4
    Nice!
    Will have a play with it soon methinks.
    Any chance of an AROS compile seeing as you are using DevCpp? ;-)
  • »07.04.07 - 04:25
    jahc
    Nice!
    Yes, thats the plan.
  • »07.04.07 - 05:13
    Amigaz
    Posts: 121 from 2005/6/11
    Awasome! thanks
    Gonna try it later today on my A4000
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »07.04.07 - 06:29
    Posts: 109 from 2006/9/10
    Thanks Jahc, that's really great news! I was already using the 68k-version (which already ran great), but will switch to the MOS-native version now. :-)
    I wish more developers would show such an interest and openess towards different Amigaish platforms like you do!
  • »07.04.07 - 08:37
    hooligan
    Posts: 1948 from 2003/2/23
    Thank you Jahc, very kind from you. Make it aN Amirc killer ;-)
  • »07.04.07 - 09:48
    MorphDelf
    Posts: 274 from 2004/2/20
    Very nice program! Now for MorphOS aswell. I like it a lot.
    Thanks for supporting *MorphOS* atlast :)
    Regards,
    Michal
    [ Edited by MorphDelf on 2007/4/7 13:48 ]
  • »07.04.07 - 10:45
    Framiga
    Posts: 363 from 2003/7/11
    Thanks, jahc! :-)
    EDIT- theres a problem clicking twice on the nick list (query?)
    here the logtool dump.
    MOS for PowerUP 1.4.5, MUI 3.9, MOSNet 1.2 with Scalos
    Same hit on Ambient with MUI4
    [ Edited by Framiga on 2007/4/7 15:09 ]
  • »07.04.07 - 11:02
    AmigaMancer
    Posts: 265 from 2005/8/25
    Thanks you. I knew that this would happened one day. ;-)
    Amiga 1200 user.
  • »07.04.07 - 13:56
    analogkid
    Posts: 716 from 2004/11/3
    great work jahc! but i stay with AmIRC, it's simply the best :) but wookie ist great, too.
  • »07.04.07 - 14:43
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 14.09.2011 - 10:36 ]
    Pegasos2 G3, 512 megs RAM
  • »07.04.07 - 15:24
    Posts: 108 from 2005/4/3
    Hi all,
    WookieChat seems flawlesly do it's job. I tested the programm.
    The main reason i installed the programm is it's name and icon !
    I'am registered for the good old 68K AmIRC, but replaced it with the Chewie !
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »07.04.07 - 18:56
    analogkid
    I admit, that's the great advantage WookieChat has for beginners in the IRC world. But I've registered AmIRC for quite some time, and I'll continue using it. I like the handling of AmIRC. But as I said, WookieChat is great, too.
    [ Edited by analogkid on 2007/4/8 9:23 ]
  • »08.04.07 - 07:22
    kriz
    Posts: 312 from 2005/10/18
    I had to send jahc some money, it is a fucking good irc client!
    Mirc/Amirc killer!
    Thanks.
    [ Edited by kriz on 2007/4/8 10:42 ]
  • »08.04.07 - 07:41
    jahc
    My hands are sore and weak from porting intensively to MOS and AROS the past few days.. My last session was from about 10pm to 3am.. So I'm just taking it easy at the moment. I'll try and fix the problems people have reported in a few days once some fitness returns to my fingers. :)
    About my RSI: If I just use computers generally, my fitness does return slowly. It's only when I'm programming for hours and trying to achieve something that I start to get weak or sore. So dont worry about me, I'll be fine in a few days!
    EDIT: I've fixed the issues that people have reported to me.. From the changelog:
    - Added sanity check for NULL objects when setting up and killing notifys on certain GUI elements. Switching to/from private tabs no longer crashes on MorphOS.
    Download from here:
    EDIT2: Whoops! I forgot to compile with -noixemul. I've just uploaded the -noixemul compile now. Thank you to Framiga for pointing out my error. :)
    [ Edited by jahc on 2007/4/9 20:48 ]
    [ Edited by jahc on 2007/4/9 23:42 ]
  • »09.04.07 - 01:31
    kriz
    Take care man ;) Done over work yourself hehe..
  • »09.04.07 - 07:46
