In the prefs menu, You can change the resolution.
BTW: If You can use version 5 or greater (development still continue, but very sslllooow and Amiga OS 4 oriented!
 You can use the rtg of Cybergfx with any resolution.
In the development version, the render engine is separated from the program: lots faster in reder complex anim or image
 [ Edited by flip on 2007/4/2 22:54 ]
