Voodoo 3500 AGP + Peg 1 (No April) - TV card no workee
    mdma
    Posts: 85 from 2003/5/4
    I'm having a spot of trouble trying to get TV card functionality working with my Voodoo 3500 card.
    I've tried AmithlonTV and all the drivers it lists, and also Visionary and all the drivers that come with that too.
    Thinking to myself that it could be an articia problem, i plugged in a PCI bt878 card, but neither software package worked with that either.
    Am I doomed to have no TV card support?
    Output from OpenPCIInfo follows if it's any use to someone.
    Thanks in advance, Nik.
    OpenPciInfo v1.5 12.03.2005 by Titan
    openpci.library v2.1 opened
    Bus Pegasos detected
    Internal Configuration Space infos
    VendorID : $10cc
    DeviceID : $661
    ClassRevision : $06040000
    PCI_REVISION_ID $00
    Header Type : $01 (0=Normal/1=Bridge/2=Cardbus)
    Command : $0007
    I/O space PCI_COMMAND_IO
    Memory space PCI_COMMAND_MEMORY
    Bus mastering PCI_COMMAND_MASTER
    PCI_LATENCY_TIMER : $20
    Pci Device Slot Num : 1, Func Num : 0
    Vendor :
    Device :
    VendorID : $10cc
    DeviceID : $661
    ClassCode: 0x060400
    IRQNumber: 73
    Bus Master Capable
    Card PCI_STATUS
    Support 66 Mhz PCI 2.1 bus
    Doesn't accept fast-back to back
    What's Enabled in the Card ?
    VendorID : $1106
    DeviceID : $3044
    ClassRevision : $0c001046
    PCI_REVISION_ID $46
    Header Type : $00 (0=Normal/1=Bridge/2=Cardbus)
    PCI_SUBSYSTEM_ID $4430
    Command : $0000
    PCI_LATENCY_TIMER : $00
    Pci Device Slot Num : 6, Func Num : 0
    Vendor : VIA Technologies Inc
    Device : VT63061 VIA Fire II 1394a OHCI Link Layer Ctrlr1
    VendorID : $1106
    DeviceID : $3044
    ClassCode: 0x0c0010
    IRQNumber: 9
    MemAddr0 : $efffe000 - $efffefff 4 kbytes
    IOAddr1 : $efffd000 - $efffdfff 4 kbytes
    Bus Master Capable
    Card PCI_STATUS
    Doesn't support 66 Mhz PCI 2.1 bus
    VendorID : $1106
    DeviceID : $8231
    ClassRevision : $06010010
    PCI_REVISION_ID $10
    Header Type : $80 (0=Normal/1=Bridge/2=Cardbus)
    Command : $0007
    Pci Device Slot Num : 7, Func Num : 0
    Device : VT8231 PCI to ISA Bridge
    VendorID : $1106
    DeviceID : $8231
    ClassCode: 0x060100
    IRQNumber: 0
    Bus Master Capable
    Card PCI_STATUS
    VendorID : $1106
    DeviceID : $571
    ClassRevision : $01018f06
    PCI_REVISION_ID $06
    PCI_SUBSYSTEM_ID $0000
    Command : $0007
    Pci Device Slot Num : 7, Func Num : 1
    Device : VT82C596 PCI IDE Controller
    VendorID : $1106
    DeviceID : $571
    ClassCode: 0x01018f
    IRQNumber: 14
    IOAddr0 : $efffc000 - $efffcfff 4 kbytes
    IOAddr1 : $efffb004 - $efffc003 4 kbytes
    IOAddr2 : $efffa000 - $efffafff 4 kbytes
    IOAddr3 : $efff9004 - $efffa003 4 kbytes
    IOAddr4 : $efff8000 - $efff8fff 4 kbytes
    Bus Master Capable
    Card PCI_STATUS
    Accept fast-back to back
    VendorID : $1106
    DeviceID : $3038
    ClassRevision : $0c030019
    PCI_REVISION_ID $19
    PCI_SUBSYSTEM_ID $1234
    Command : $0007
    PCI_LATENCY_TIMER : $16
    Pci Device Slot Num : 7, Func Num : 2
    Device : VT83C572, VT6202 USB 1.0 Controller
    VendorID : $1106
    DeviceID : $3038
    ClassCode: 0x0c0300
    IRQNumber: 9
    IOAddr4 : $efff7000 - $efff7fff 4 kbytes
    Bus Master Capable
    Card PCI_STATUS
    VendorID : $1106
    DeviceID : $3038
    PCI_REVISION_ID $19
    Command : $0007
    Pci Device Slot Num : 7, Func Num : 3
    VendorID : $1106
    DeviceID : $3038
    ClassCode: 0x0c0300
    IRQNumber: 9
    IOAddr4 : $efff6000 - $efff6fff 4 kbytes
    Bus Master Capable
    Card PCI_STATUS
    VendorID : $1106
    DeviceID : $8235
    ClassRevision : $00000010
    PCI_REVISION_ID $10
    Command : $0000
    Pci Device Slot Num : 7, Func Num : 4
    Device : VT8235 Power Management Controller
    VendorID : $1106
    DeviceID : $8235
    ClassCode: 0x000000
    IRQNumber: 0
    No Bus Master Capable
    Card PCI_STATUS
    VendorID : $1106
    DeviceID : $3058
    ClassRevision : $04010040
    PCI_REVISION_ID $40
    Command : $0001
    Pci Device Slot Num : 7, Func Num : 5
    Device : VT82xxxxx AC97 Audio Codec (All VIA Chipsets)
    VendorID : $1106
    DeviceID : $3058
    ClassCode: 0x040100
    IRQNumber: 9
    IOAddr0 : $efff5000 - $efff5fff 4 kbytes
    IOAddr1 : $efff4000 - $efff4fff 4 kbytes
    IOAddr2 : $efff3000 - $efff3fff 4 kbytes
    Card PCI_STATUS
    VendorID : $1106
    DeviceID : $3068
    ClassRevision : $07800020
    PCI_REVISION_ID $20
    Command : $0000
    Pci Device Slot Num : 7, Func Num : 6
    Device : VT82C686/686A/686B AC97 Modem controller
    VendorID : $1106
    DeviceID : $3068
    ClassCode: 0x078000
    IRQNumber: 9
    IOAddr0 : $efff2000 - $efff2fff 4 kbytes
    Card PCI_STATUS
    VendorID : $1106
    DeviceID : $3065
    ClassRevision : $02000051
    PCI_REVISION_ID $51
    PCI_SUBSYSTEM_ID $ffff
    Command : $0007
    Pci Device Slot Num : 8, Func Num : 0
    Device : VT6102 Rhine II PCI Fast Ethernet Controller
    VendorID : $1106
    DeviceID : $3065
    ClassCode: 0x020000
    IRQNumber: 9
    IOAddr0 : $efff1000 - $efff1fff 4 kbytes
    MemAddr1 : $efff0000 - $efff0fff 4 kbytes
    Bus Master Capable
    Card PCI_STATUS
    VendorID : $10ec
    DeviceID : $8139
    ClassRevision : $02000010
    PCI_REVISION_ID $10
    PCI_SUBSYSTEM_ID $434e
    Command : $0007
    Pci Device Slot Num : 10, Func Num : 0
    Vendor : Realtek Semiconductor
    Device : RTL8139A/B/C Fast Ethernet Adapter
    VendorID : $10ec
    DeviceID : $8139
    ClassCode: 0x020000
    IRQNumber: 9
    IOAddr0 : $effef000 - $effeffff 4 kbytes
    MemAddr1 : $effee000 - $effeefff 4 kbytes
    Bus Master Capable
    Card PCI_STATUS
    VendorID : $109e
    DeviceID : $36e
    ClassRevision : $04000002
    PCI_REVISION_ID $02
    Command : $0006
    Pci Device Slot Num : 11, Func Num : 0
    Vendor : Brooktree Corporation
    Device : 3 MediaStream Controller
    VendorID : $109e
    DeviceID : $36e
    ClassCode: 0x040000
    IRQNumber: 9
    MemAddr0 : $effed000 - $effedfff 4 kbytes
    Bus Master Capable
    Card PCI_STATUS
    VendorID : $109e
    DeviceID : $878
    ClassRevision : $04800002
    PCI_REVISION_ID $02
    Command : $0000
    Pci Device Slot Num : 11, Func Num : 1
    Device : Bt878 Video Capture
    VendorID : $109e
    DeviceID : $878
    ClassCode: 0x048000
    IRQNumber: 9
    MemAddr0 : $effec000 - $effecfff 4 kbytes
    Bus Master Capable
    Card PCI_STATUS
    VendorID : $121a
    DeviceID : $5
    ClassRevision : $03000001
    PCI_REVISION_ID $01
    PCI_SUBSYSTEM_ID $0061
    Command : $0003
    Pci Device Slot Num : 0, Func Num : 0
    Vendor : 3dfx Interactive Inc
    Device : Voodoo3 All Voodoo3 chips, 3000
    VendorID : $121a
    DeviceID : $5
    ClassCode: 0x030000
    IRQNumber: 9
    MemAddr0 : $edfec000 - $effebfff 32768 kbytes
    MemAddr1 : $ebfec000 - $edfebfff 32768 kbytes
    IOAddr2 : $ebfeb000 - $ebfebfff 4 kbytes
    RomAddr : $ebfdb000 - $ebfeafff
    RomSize : 65536 bytes 64 kbytes
    Card PCI_STATUS
    2048bytes MEM_PCI DMA Mem Allocated : 212cd604
    16384bytes MEM_PCI DMA Mem Allocated : 21a10124
    Free Mem 2048
    2040bytes MEM_NONCACHEABLE DMA Mem Allocated : 216a0da4
    Free Mem 2040
    4096bytes MEM_NONCACHEABLE DMA Mem Allocated : 216af754
    Free Mem 4096
    Free Mem 16384
    300000 bytes MEM_NONCACHEABLE DMA Mem Allocated : 21fefacc
    Free Mem 300000
  • »25.03.07 - 12:42
    magnetic
    Posts: 2129 from 2003/3/1
    Hi
    Voodoo3500 tv does NOT work with public programs. There is a private beta driver from a while ago that works with it and Visiionary..
    magnetic
  • »25.03.07 - 16:27
    mdma
    So is there anychance a mere mortal can get hold of such things?
  • »25.03.07 - 18:12
    Crumb
    Posts: 737 from 2003/2/24
    send a donation to Frank and cross your fingers
  • »25.03.07 - 20:18
    magnetic
    Good idea crumb
    MDMA: Frank is Frank Mariak author of Cybergrafx and mos team member make a paypal donation and request the Visionary driver.
    magnetic
  • »25.03.07 - 20:29
    mdma
    Thanks for the help guys.
    End of the month should be fine :-)
  • »26.03.07 - 16:02
