MOSNet 100MB/s
    mdma
    Posts: 85 from 2003/5/4
    My Peg only appears to be connecting to my router at 10MB/s whether I use the onboard VIA junk or an rtl8139 card.
    I've looked around all the config files in the db directory but nothing obvious there.
    Does anyone know how to set the LAN speed to 100MB/s using MOSNet?
  • »23.03.07 - 15:45
    Posts: 1087 from 2003/3/24
    It's 100Mbit/s not MB. So you will get 3-8MB/s, thats what i get when i push some date to my PC or from PC to the Peg.
  • »23.03.07 - 15:51
    catohagen
    Posts: 297 from 2003/5/20
    look in env:sana2/ dir
    there should be a rtl_8139pci_0.config and options are
    10BASET/S,100BASETX/S,FULLDUPLEX/S
    for via_rhinepci_0.config you can set
    10BASET/S,100BASETX/S,FULLDUPLEX/S,AUTONEGOTIATE/S
    edit these
  • »23.03.07 - 16:16
    mdma
    edit these
    I don't have such a dir on my machine.
    A search for #?.config#? shows general.config in the mosnet/db dir and a couple of unrelated things in the SDK dir.
  • »23.03.07 - 16:26
    mdma
    Yes, typo on my behalf.
    The MOSNet GUI shows "Speed: 10M", whereas it should say "Speed 100M" as both my router and ethernet support 100Mb/s.
  • »23.03.07 - 16:37
    mdma
    *bump*
    Any ideas gents?
  • »24.03.07 - 00:45
    Motosampy
    Posts: 199 from 2004/8/14
    I have not tested speeds, but atleast my router reports that Peg2 is connected at 100M on HW level eventhoug Mosnet GUI says 10M.
  • »24.03.07 - 04:33
    Wishmaster
    Posts: 342 from 2003/6/29
    Your connection is already running at 100MBit.
    MOSNet is only reporting a wrong value.
    You can disable it in the preferences.
    [ Edited by Wishmaster on 2007/3/24 10:48 ]
    Pegasos PPC
  • »24.03.07 - 07:47
    Get AmiTradeCenter and move some Files in your Network, then you can see how fast or slow the connection is.
  • »24.03.07 - 08:26
    Posts: 1521 from 2003/2/24
    Here MOSNet reports 100M.
  • »24.03.07 - 10:33
    Motosampy
    To a PC that has a 10M only network interface... Over powerline-ethernet bridge that supports upto about 10Mbit/s.... yep..... :)
  • »24.03.07 - 12:57
